Wire - Master Receiver/Slave Sender behavior
I’m sorry for being such a noob.
I still don’t get the point in this:
These codes are from the examples provided from the arduino package.
Master Receiver:
#include <Wire.h>
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Wire.requestFrom(5, 6);    // request 6 bytes from slave device #2
  while(Wire.available())    // slave may send less than requested
    char c = Wire.read(); // receive a byte as character
    Serial.print(c);         // print the character
Slave sender:
#include <Wire.h>
  Wire.begin(5);                // join i2c bus with address #2
  Wire.onRequest(requestEvent); // register event
  delay(100);
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void requestEvent()
  Wire.write("hello "); // respond with message of 6 bytes
                       // as expected by master
WHen I copy and paste the snippets into my project it all works fine. Now, if I alter the sent data from string to single char like this:
void requestEvent()
 Wire.write("h");
 Wire.write("e");
 Wire.write("l");
 Wire.write("l");
 Wire.write("o");
 Wire.write(" ");
it stops working.
Can someone explain to me what’s happening here? Originally I am trying to send a long in a union bytewise, that doesn’t work whenever I try to transmit more than one byte at once using different lines (like, in a loop) it sends empty bytes.
If that matters I’m using Nanos on both ends.
Hi spacko
Problem may be multiple writes in event handler. There is a solution in this thread, using byte array and a single write:
http://forum.arduino.cc/index.php/topic,109335.0.html
Regards
Ray
Thank you very much Ray,
that has put me on the right track. I actually had to transfer a “long” and couldn’t just transfer bytes in a for-loop.
Solution looks as follows for Master:
union sendsum {
  long usumme;
  byte b[4];
 union sendsum usum;
  if (Wire.requestFrom (5, sizeof usum) == sizeof usum){
       for (int i = 0; i < sizeof usum; i++)
         usum.b[i] = Wire.read ();
and for Slave:
long sum;
byte data[4];
  data[0] = sum;
  data[1] = sum>>8;
  data[2] = sum>>16;
  data[3] = sum>>24;
void requestEvent(){
  Wire.write(data,4);
It can be that simple…
Thanks again, I really appreciate it!
hello ' i need code master receiver /slave writer char or int just code work
