Wired pressure transducer
Hello everyone,
I have a wired pressure transducer and I want to connect to a phone or computer to show the pressure information.
I saw some people using UNO R3 with breadboard and LCD screen. Is it possible to send the reading to the phone or computer without using LCD screen?
Thanks
Sure, you could use bluetooth, SMS or any other available technology.
What method will you use on the phone side?
I've tried the Bluetooth,but the problem is that when I pressurize the device there's a delay time reading the pressure form the phone. The phone doesn't show the change in pressure instantly
Hello
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
I'm not expert in Arduino stuff, I just want to know if it's possible to connect it to a phone. I have the code to connect to an LCD screen but not a phone.
To answer your question, Yes.
Such things do take some time.
Can you quantify the delay time? If your current delay is not acceptable can you suggest what would be acceptable.
You mentioned a computer, an Arduino outputting data from its serial port to a logic to USB converter (small inexpensive device) would have the minimum delay achievable.
