Hi guys
I'm currently working on a project where i stream music to my Arduino Uno using a wifly and sparkfun mp3 shield.
But quality sucks! so bad that u can't even reqognize the song.
So if anyone knows how i can optimize my code would be helpfull.
Thanks!
//---include area
#include <SPI.h>
#include "WiFly.h"
#include "Credentials.h"
//---variable declaration
//ethernet card related
byte server[] = { 192, 168, 1, 24 }; // Write server IP address here
Client client(server, 6000); //connect to this port on the server and send local IP address
Client client2(server, 8080); //connect to this port on the server to receive stream
unsigned char data0;
//** Ethernet chip pin assignment
#define ETHER_CS 10
/** Control Chip Select Pin (for accessing SPI Control/Status registers) */
#define MP3_XCS 6
/** Data Chip Select / BSYNC Pin */
#define MP3_XDCS 7
//** Data Request Pin: Player asks for more data */
#define MP3_DREQ 2
#define MP3_RST 8
/** VS10xx SCI Registers */
#define SPI_MODE 0x0 /**< VS10xx register */
#define SPI_STATUS 0x1 /**< VS10xx register */
//#define SPI_BASS 0x2 /**< VS10xx register */
#define SPI_CLOCKF 0x3 /**< VS10xx register */
//#define SPI_DECODE_TIME 0x4 /**< VS10xx register */
#define SPI_AUDATA 0x5 /**< VS10xx register */
//#define SPI_WRAM 0x6 /**< VS10xx register */
//#define SPI_WRAMADDR 0x7 /**< VS10xx register */
//#define SPI_HDAT0 0x8 /**< VS10xx register */
//#define SPI_HDAT1 0x9 /**< VS10xx register */
//#define SPI_AIADDR 0xa /**< VS10xx register */
#define SPI_VOL 0xb /**< VS10xx register */
//#define SPI_AICTRL0 0xc /**< VS10xx register */
//#define SPI_AICTRL1 0xd /**< VS10xx register */
//#define SPI_AICTRL2 0xe /**< VS10xx register */
//#define SPI_AICTRL3 0xf /**< VS10xx register */
//---functions area
//enable the ethernet chip on the SPI bus
void EtherSelect(){
digitalWrite(ETHER_CS, LOW);
//disable the ethernet chip on the SPI bus
void EtherDeselect(){
digitalWrite(ETHER_CS, HIGH);
//mp3 card related
unsigned char SPIGetChar(){
unsigned char returned = SPI.transfer(0xFF);
return returned; /* Return the received byte */
/** Pull the VS10xx Control Chip Select line Low */
void Mp3SelectControl(){
digitalWrite(MP3_XCS, LOW);
/** Pull the VS10xx Control Chip Select line High */
void Mp3DeselectControl(){
digitalWrite(MP3_XCS, HIGH);
/** Pull the VS10xx Data Chip Select line Low */
void Mp3SelectData(){
digitalWrite(MP3_XDCS, LOW);
/** Pull the VS10xx Data Chip Select line High */
void Mp3DeselectData(){
digitalWrite(MP3_XDCS, HIGH);
void SPIWait(){
while (!digitalRead(MP3_DREQ)){};
/** Write VS10xx register */
void Mp3WriteRegister(unsigned char addressbyte, unsigned char highbyte, unsigned char lowbyte){
Mp3DeselectData();
Mp3SelectControl();
delay(1);
SPI.transfer(0x02); //write command
SPI.transfer(addressbyte);
SPI.transfer(highbyte);
SPI.transfer(lowbyte);
SPIWait();
Mp3DeselectControl();
/** Set VS10xx Volume Register */
void Mp3SetVolume(unsigned char leftchannel, unsigned char rightchannel){
Mp3WriteRegister(SPI_VOL,leftchannel,rightchannel);
void InitMicrocontroller(){
SPI.setClockDivider(SPI_CLOCK_DIV64);//slow SPI bus speed
SPI.transfer(0xFF);
void SPIInit(){
//max SDI clock freq = CLKI/7 and (datasheet) CLKI = 36.864, hence max clock = 5MHz
//SPI clock arduino = 16MHz. 16/ 4 = 4MHz -- ok!
SPI.setClockDivider(SPI_CLOCK_DIV2);
/** Soft Reset of VS10xx (Between songs) */
void Mp3SoftReset(){
InitMicrocontroller();
Mp3WriteRegister (SPI_MODE, 0x08, 0x44);
/* Newmode, Reset, No L1-2, stream enabled */
delay(1); /* One millisecond delay */
SPIWait();
/* Set clock register, doubler etc. */
Mp3WriteRegister(SPI_CLOCKF, 0x88, 0x00);
SPIWait();
SPIInit();
Mp3SetVolume(0xff,0xff); //Declick: Immediately switch analog off
/* Declick: Slow sample rate for slow analog part startup */
Mp3WriteRegister(SPI_AUDATA, 0, 10); /* 10 Hz */
delay(100);
/* Switch on the analog parts */
Mp3SetVolume(0xfe,0xfe);
Mp3WriteRegister (SPI_AUDATA, 0xAC, 0x45);//stereo, 44100KHz sampling
Mp3SetVolume(20,20); // Set initial volume (20 = -10dB)
//---pin and cards initialization - setup()
Serial.println("Initializing...");
pinMode(MP3_DREQ, INPUT);
pinMode(MP3_XCS, OUTPUT);
pinMode(MP3_XDCS, OUTPUT);
pinMode(ETHER_CS, OUTPUT);
pinMode(MP3_RST, OUTPUT);
digitalWrite(MP3_RST, HIGH);
WiFly.begin();
SPI.begin();
if (!WiFly.join(ssid)) {
Serial.println("Association failed. Shield needs a reset.");
while (1) {
// Hang on failure.
Serial.print("IP: ");
Serial.println(WiFly.ip());
Mp3SoftReset();
//---main - loop()
void loop(){
char c ='0';
EtherSelect();
if (client.connect()){
client.flush();
delay(100);
client.println("10.0.0.2");
delay(200);
c = client.read();
delay(100);
//c = client.read();
//delay(100);
Serial.println(c);
client.println("bye");
delay(200);
client.stop();
delay(100);
else Serial.println("Connection to port 6000 is not available!");
EtherDeselect();
switch (c){
case 'p':
//what to do if server is asking client to play the stream:
EtherDeselect();
Mp3SoftReset();
EtherSelect();
if (client2.connect()){
delay(10);
Serial.println("Connected to data transfer port!");
client2.println("GET / HTTP/1.1");
client2.println();client2.println();
delay(1);
while (client2.connected()){
EtherSelect();
data0 = client2.read();
EtherDeselect();
SPIWait();
Mp3SelectData();
SPI.transfer(data0);
delay(1);
Mp3DeselectData();
//shutdown Ethernet
client2.flush();
client2.stop();
EtherDeselect();
//Shutdown player
Mp3SelectData();
for (int i=0; i<2048; i++) {
while (!digitalRead(MP3_DREQ)); // wait here until DREQ is high again
SPI.transfer(0x00);
SPIWait(); // Wait until SPI transfer is completed
Mp3DeselectData();
EtherSelect();
else Serial.println("Failed connection to streaming server!");
Serial.println("Status 1");
case 'n':
//what to do if server is asking for client not to play the stream
Serial.println("Status 2");
default:
//what to do in all other commands (faulty) sent by server
Serial.println("Status 3");
