Wireless "charging" module.
I have a Seeedstudio wireless charging module.
http://www.seeedstudio.com/depot/wireless-charging-module-p-1354.html?cPath=155
12VDC in and 5VDC out.
As the output is not grounded could I connect two units in series to give 10V output?
I'm thinking of having the 12VDC inputs in parallel.
Veganic:
Yes.
You might be better off with a voltage boostor on the output though (depending on how many amps you need).
Thanks, I'll give it a try and have a look into voltage boosters.
I'm aiming to get the current down to <100mA but the test unit might be closer to 500mA.
It is OEM by ElecFreaks ?
ElecFreaks is an open hardware facilitation company based in Shenzhen, China.
I voted anything is open, The output can be customized to 3.3V 5V 9V 12V etc.
http://www.elecfreaks.com/ figure out yourself.
