I'm following this tutorial (Arduino Project Hub) to build a robot controlled by a PS2 controller. The two arduinos communicate via HC-12 wireless modules. I'm getting some serious lag somewhere making the robot useless. If I press buttons for 2 seconds or less, everything is fine. But if I hold them down, the robot keeps going for a long time after I release the button. I've added some println comments to troubleshoot and the issue doesn't appear to be happening in the transmitter arduino. It seems to be either in the wireless communication or the receiver arduino. The only major modification I made to the tutorial is that we bought cheap clone PS2 controller and the joysticks don't work (instead of 0, 128, 255 they are 0, 0, 255 so they don't detect up or left movement). Now that I watch the video on the tutorial page, it seems to have some lag as well.
What can I do?
Here is the code. First time posting code, so forgive me if it doesn't come through well.
Transmitter Arduino:
#include <PS2X_lib.h>
#include<SoftwareSerial.h>
SoftwareSerial mySerial(6,7); //HC-12 tx pin, rx pin
PS2X ps2x;
ps2x.config_gamepad(5,4,3,2, false, false); //GamePad(clock, command, attention, data, Pressures?, Rumble?)
mySerial.begin(9600);
pinMode(LED_BUILTIN, OUTPUT);
void moveForward(){
mySerial.println("1");
Serial.println("FORWARD");
void moveBackward(){
mySerial.println("2");
Serial.println("BACKWARD");
void turnRight(){
mySerial.println("3");
Serial.println("RIGHT");
void turnLeft(){
mySerial.println("4");
Serial.println("left");
void turnClockwise(){
mySerial.println("5");
Serial.println("clock");
void turnAnticlockwise(){
mySerial.println("6");
Serial.println("anticlock");
void moveServo(){
Serial.println("Servo");
ps2x.read_gamepad();
if(ps2x.Button(PSB_PAD_DOWN)){
moveBackward();
if(ps2x.Button(PSB_PAD_UP)){
moveForward(); //turn off left motor
if(ps2x.Button(PSB_RED)){
turnClockwise();
if(ps2x.Button(PSB_PINK)){
turnAnticlockwise();
if(ps2x.Button(PSB_R1)){
moveServo();
Receiver Arduino:
SoftwareSerial mySerial(2, 3); //HC-12 tx pin, rx pin
int in1=4, in2=5, in3=6, in4=7; //Motor driver pins
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
void moveForward(){
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
void moveLeft(){
void moveRight(){
void clockwise(){
void anticlockwise(){
if(mySerial.available()>0){
int input = mySerial.read();
if(input=='1'){
Serial.println("FORWARD1");
moveForward();
if(input=='2'){
Serial.println("BACKWARD1");
moveBackward();
if(input=='3'){
Serial.println("RIGHT1");
moveRight();
if(input=='4'){
Serial.println("LEFT1");
moveLeft();
if(input=='5'){
Serial.println("CLOCKWISE");
clockwise();
if(input=='6'){
Serial.println("ANTICLOCKWISE");
anticlockwise();
delay(190);
else{
Thanks in advance!
