Wireless communication
Hello guys… I am new to your forum…
I have a question…
I have done a wireless communication between two arduinos with Virtual wire…!
I can send any char i want… now i want to measure temp and send the TEmp to the other arduino and see in on the Lcd…
The Virtualwire sends only Char?? i have to convert the Integer ( temp) in char in order to send it? or what??
Here is my code till now…
Transmitter code
#include <VirtualWire.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
Serial.begin(4800); // Debugging only
Serial.println(“setup”);
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
const char *msg = “hello”;
digitalWrite(13, true); // Flash a light to show transmitting
vw_send(uint8_t *)msg;
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(13, false);
delay(200);
Reciever Code
#include <LiquidCrystal.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
Serial.begin(4800);
vw_setup(2000);
vw_set_rx_pin(7);
vw_rx_start();
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
digitalWrite(9, true);
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13;
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH);
lcd.begin(16,2);
for (i = 0; i < buflen; i++)
lcd.setCursor(0,0);
lcd.print(“Temp:”);
lcd.setCursor(i,1);
lcd.print(buf*);*
_ Serial.print(buf*);_
_
Serial.print("");_
_
}_
_
Serial.println("");_
_
digitalWrite(9, false);*_
[/color]
Soz for my english and for my bad skill in programming :slight_smile: :slight_smile:
The VirtualWire class sends bytes, not chars. If temp is an integer, it is two bytes long.
This won't even compile.
    vw_send((uint8_t *)temp, 2);
will send the two byte integer, temp, across.
PaulS:
Yeap you are right.. i erased some comments and i erased and some code..
vw_send((uint8_t *)msg, strlen(msg)); here is what i had...
Ok i undestood i wish i do it.. :) :)
THank you!
what do you think is the simpliest code to use with the Ds18B20 temp sensor??
Thank you!
