Wireless communications
I am building a fridge control unit (to replace the original one) and was thinking to use the Arduino Nano so I could plug a long USB cable and do some debugging / reflashing over a standard USB.
However in order to avoid having a USB cable sticking out I was thinking of something wireless. I have never done anything similar with the Arduino.
I imagine I would be able to connect to the Arduino Nano using my laptop, but instead of a very long USB cable it would be wireless.
I have started looking at the ESP8266 and been reading about it, but there are so many models and am getting confused.
Thanks for any ideas advice offered
Bluetooth is probably the simplest if all you want to do is get messages from the Nano about the behaviour of the fridge. Bluetooth is really just serial-by-wireless.
I am controlling a 230v fridge with an Atmega 328 on stripboard. It controls a relay to turn the fridge on and off depending on the temperature in the freezer compartment. I have two headers on it so I can {A} re-program it by connecting to the PC with a USB-TTL cable and so that I can {B} read data without resetting the Atmega. Nowadays (2 years later) I NEVER study the data.
...R
Hello
Mine is slightly more complicated, it has two lamps, two fans, the compressor, the defrost heater (you have to run a defrost cycle every now and then), three temp sensors, a reed switch board...
So I am thinking I might need to study the data and keep an eye on it before I have understood all the workings.
Because fridges can work for decades without maintainance (eg broken compressor/refilling etc), it has to be done right :slight_smile:
I will look around for Bluetooth as per your suggestion.
Perhaps I did not explain myself adequately. I did not mean to say that monitoring is useless - rather that its long-term value will probably decline and a simple though inconvenient connection system may be sufficient because it will not need to be used very often.
But Bluetooth should not be difficult to implement.
...R
Simple answer? Bluefruit EZ-Link - Bluetooth Serial Link & Arduino Programmer [v1.3] : ID 1588 : $22.50 : Adafruit Industries, Unique & fun DIY electronics and kits
Great, but I have decided I want a WiFi connection, not bluetooth because it will allow greater ranges (even outside the house!).
I have posted the relevant question in a more appropriate forum here: Remote connection to Arduino boards - Home Automation - Arduino Forum
Try this.
Alas, only the Linux version of AVR-Dude supports programming over a telnet connection.
