Wireless connection: possible alternatives
Dear all,
For my project I have the arduino uno connected via serial to a RPi which has a wi-fi connection. Unfortunately these are placed outside, protected by humidity but subject to low temperatures.
While arduino it seems to work fine (atmega328 should work between -40°C and 85°C) I'm not that sure about RPi and about my wi-fi adapter (which died at 0°C).
Now I would like to move RPi inside and have the Arduino outside, but cannot have a long serial cable.
The distance would be around 10m with one wall in the middle.
So far I identified the following alternatives:
  • VirtualWire: using 433MHz modules (signal seems to arrive since I also have remote plugs at the same frequency). The RPi would be connected to an additional arduino to get the signal. Possible interference with 433MHz
  • NRF24L01+: (these) are 3.3V, but input (not VCC) should be tollerant 5V (datasheet). It seems that multiple nodes can be added in future in case of need. Possible interference with wi-fi.
    Can I use these also if I have other things connected via SPI? For CE and CSN can I use any digital pin?
  • Bluetooth: (JY-MCU). Not clear if I'm able to cover the range with this (considering the wall). Can I connect it to the RPi using any bluethooth adapter and use it like if it is a serial connection?
  • New wifi adapter for RPi: but not sure if the RPi resists below 0°C.
Which option do you suggest?
Do you have any other ideas/pro/cons?
Thank you for your support,
dk
I'll be watching the responses with interest & if we could add to the above query "what would be the best solution if one wanted to use it for a networked application with a Master to 1+ Slaves"
Regards all
Why don't you use an RN-XV module on the Arduino? It's Wifi you might ommit the Raspberry Pi completely (you didn't specify what you use it for). The datasheet says it's operating down to -40°C. This way at least you don't need another device for the RaspPi.
