I want to connect 2 boards with wireless module.
I tried nRF24l01 but it had connection issues even in my house - second arduino was in next room (~5m).
Which module will cover 15m distance through the walls? Close to one board will be 11kW engine.
They communicate between but even I connect to one module 12dBi antenna communiation distance was only couple meters longer and was not long enough for me.
Now I'm in other flat and here are worse conditions for 2.4GHz - a lot of wifi routers.
Here I'm testing this modules but modules without antennas have better communication than these with antenna
Now they are connected directly to arduino with wires not by the IO shield
distance between boards:~5m
Near are 12 WiFi networks so it's hard to find free channel
In next wekk modules will be tested in free space now I don't have such option.
For now modules without antenna are better than modules with antenna
Please display your image(s) in your post so we can see it(them) without downloading it(them). See this Simple Image Guide
Your comments in Reply #7 do not really tell us if you have solved the problem, or if you have made some progress or if you still need help and what you still need help with.
And you have not answered my questions in Reply #6
I believe the high-power modules (with external antenna) needs more current than the low power versions so maybe the shield is not providing enough. Try powering the nRF24 from 2 x AA alkaline cells (3v) with the GND connected to the Arduino GND.
I think you can also have problems with the high-power versions if they are too close together.
