Wireless Control, XBee or RF?
Hey guys-
I'm trying to make a small project with 2 Arduinos, both would be controlled wirelessly.
One arduino would be the "controller" with a simple joystick on it, but would need to transmit the potentiometer values to the second Arduino which would be connected to the receiver and would be controlling 2 motors, using PWM for speed control.
Ideally I would like to use RF or something similar to it, because I have never used it before, and would like to learn it, and because it is SO much cheaper to use. However, I was reading some about it, and a few problems seem to arise with those: 1) Interference out the wazoo. 2) Would they be able to support PWM, very accurately?
Range is not a very big issue, it will all be indoors, within 200 or less feet.
Will I be able to use some RF things, or do I need to buy 2 XBee shields? :(
Maybe you can, maybe not. There are a number of "RF things" out there. Some may be useable; some may not.
The joystick can be connected directly to an XBee. No need for Arduino and XBee shield on the joystick end.
Im thinking of using these:
http://www.sparkfun.com/products/10533
http://www.sparkfun.com/products/8945
I've got them. Junk.
Xbee is awfully expensive for what you are trying to do. It absolutely has its uses, but remote control over a range of 200 feet is probably not its best use.
Have a look here:
http://www.hoperf.com/pro/rf/
An FSK (frequency shift keying) module will do the trick nicely. Depending upon hope quickly you need control update this should do. If its a toy car, easy. A plane needs them a little quicker, an ICBM, well, it won't work.
I have seen these already built as Arduino shields, but at the moment my Googling skills are not up to par :-(
