Wireless controll of servo
Hey guys, im trying to control a servo through an 433MHz RF link.
the code:
#include <ServoTimer2.h>
#include <VirtualWire.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
ServoTimer2 servo;
int i = 0;
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for RX Link Module
vw_setup(2000); // Bits per sec
vw_set_rx_pin(0); // We will be receiving on pin 23 (Mega) ie the RX pin from the module connects to this pin.
vw_rx_start(); // Start the receiver
servo.attach(A2);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // check to see if anything has been received
int i;
// Message with a good checksum received.
for (i = 0; i < buflen; i++)
Serial.print(buf*); // the received data is stored in buffer*
    _ Serial.println("");_
    _ else if(buf == 1){_
    * servo.write(0)d*
    * delay (50);*
    * else {*
    * servo.write(875);*
    * delay(50);*
    _ //else if(buf == 1){[/color]
    * // servo.write(0);
    //else if(buf == 0){[/color]
    //servo.write(1750);
    //}*_
[/quote]
But when i i upload the code to the boarf the servo dosent respond all the time. but the serial print does. can anynone see and error with the code?
Thanks in regards
        Serial.print(buf);  // the received data is stored in buffer
    Serial.println("");
     else if(buf == 1){
       servo.write(0)d
       delay (50);
     else {
         servo.write(875);
         delay(50);
This is junk. Specially the buf==1 part.
Also, a delay of 50 ms doesn't give your servo to move very far.
Korman
dunno why it put a d in there. its not in my code :confused:
and the buff == 1 should be buff == 1
but ill try and change the delay (:
