Wireless controlling servos with potentiometer using nrf24l01
Hallo , i am trying to control servo motor by potentiometer wireless using nrf24l01
if value of potentiometer get in range (0-400) servo turn left and if value if potentiometer get in range
(700-1000) servo turn right
please help . and thanks :slight_smile:
Here is a good tutorial on the use of the rf24 radios.
How to read a potentiometer.
The if statement reference.
The else statement reference.
thanks so much . i want the servo turn right if potentiometer was in range (700-100) and turn left when potentiometer in range (0-400) .
my code for rx
  • LED Connections *
  • Anode -> VCC *
  • Cathode -> GND *
  • NRF 24L01 Connection *
  • VCC -> 3.3 V *
  • GND -> GND *
  • SCK -> 13 *
  • MISO -> 12 *
  • MOSI -> 11 *
  • CSN -> 7 *
  • CE -> 8 *
//// Adding Libraries
#include <SPI.h> // to handle the communication interface with the modem
#include <nRF24L01.h> // to handle this particular modem driver
#include <RF24.h> // the library which helps us to control the radio modem
#include <Servo.h>
Servo myservo;
RF24 radio(7,8); // Creating instance 'radio' ( CE , CSN ) CE -> D7 | CSN -> D8
const byte Address[6] = " 00009 " ; // Address from which data to be received
myservo.attach(3);
Serial.begin(9600); // Setting baudrate of Serial Port to 9600
radio.begin(); // Activate the modem
radio.openReadingPipe(1, Address); // Sets the address of receiver from which program will receive the data
// radio.startListening(); // Setting modem in Receiver mode
if (radio.available())
while (radio.available()) // Loop until receiving valid data
int rx_data = 0 ; // Variable to store received data
radio.read(&rx_data, sizeof(rx_data)); // Read the received data and store in ' rx_data '
Serial.print("Received Data : ");
Serial.println(rx_data); // Print received value on Serial Monitor
myservo.write (rx_data);
// analogWrite(led_pin , rx_data); // Write received value to PWM pin 3 to which LED is connected
Serial.println("Not Receiving !!!"); // If not receiving valid data print " Not Receiving !!! " on Serial Monitor
///// END OF LOOP //////
code tx :
  • Potentiometer Connections *
  • PIN 1 -> VCC *
  • PIN 2 -> Analog input 0 i.e. A0 *
  • PIN 3 -> GND *
  • VCC -> 3.3 V *
  • GND -> GND *
  • SCK -> 13 *
  • MISO -> 12 *
  • MOSI -> 11 *
  • CSN -> 7 *
  • CE -> 8 *
#define pot_pin A0 // Variable pin of POT is to be connected to analog pin 0 i.e. A0
const byte Address[6] = " 00009 " ; // Address to which data to be transmitted
//int data ; // Creating variable to store and send data
int value = 0 ; // Creating variable to store analog input on pin A0
pinMode(pot_pin,INPUT); // Setting A0 (POT pin) as input
radio.begin (); // Activate the modem
radio.openWritingPipe (Address); // Sets the address of transmitter to which program will send the data
// radio.stopListening (); // Setting modem in transmission mode
value = analogRead(pot_pin); // Reading analog value at pin A0 and storing in varible 'value'
int data = map( value , 0 , 1023 , 0 , 180 ); // Convering the 10 bit value to 8 bit
radio.write(&data, sizeof(data)); // Sending data over NRF 24L01
Serial.print("Transmitting Data : ");
Serial.println(data); // Printing POT value on serial monitor
Read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask a good question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
So send the raw output of the pot analog input value ( 0 to 1023) instead of the mapped value (0 to 180).
In the receiver use a series of if statements to decode the pot value (rx_data).
if(rx_data > 0 && rx_data < 399)
    //turn left
else if(rx_data > 400 && rx_data < 699)
     // go striaght
else  // anything greater than 700
    // turn right
logic and (&&).
but when send signal by rf24 . i receive output from 0-255 and i can not compare this value
Did you make changes to your code? If so please post the new version so that we can keep up.
@Warawreh
DO NOT CROSS POST.
Other posts DELETED
Please read the link you were given by GroundFungus before posting any further.
Continued cross posting may result in loss of forum privileges.
BOB.
