wireless display 16x32 Matrix lcd panel using arduino mega2560( using bluetooth)
what should i use for coding in order for the matrix 16x32 display ? and what should i do it first ?
The Arduino IDE is what most people use. Try that, until you have reason to use something else.
Define some requirements. That will help you decide what hardware you need. Once you know that, the rest is pretty easy.
umm, firstly i need to use my android phone connect the anduino board by using hc-05 bluetooth and display it out on the 16x32 matrix lcd display panel. so whatever i type in the phone that will be the display on the lcd. there will be some soldering and wire wrapper on the proto shield right ? but what about the programming code ? i have read through some but i still cant understand.
