wireless guitar/mic signal transmission
Hello!
Recently I had the idea to start a project that has to do with sound signal wireless transmission. That's because I want to get rid the cable that connects my guitar with my pedals :slight_smile:
So, I checked out a bit of what I want/need:
An ADC that will sample my signal and create words as long as 24 bits (sampling rate 48KHz):
Two transceivers to establish the connection. These are capable enough to transmit 48ksps * 24 bits:
And of course two Arduinos.
Wait! What about the DAC?
Well, I haven't found any DIP packaged DAC chip so far :frowning: Any ideas?
Thank you!
Thats 140Kb a second you wish the arduino to process ( 8k every ~57ms ). Might need to wait till the due arrives.
The cheap NRF24L01 transceivers can do pretty fast transfer apparently.
EDIT: found this DAC
http://www.ebay.com.au/itm/CS4391-4391-KZ-CS4391KZ-CS4391-KZ-24-Bit-Stereo-DAC-/120852272783?pt=LH_DefaultDomain_0&hash=item1c235b568f#ht_617wt_1139
I didn't do the math for the delay. 57ms is pretty bad...I would love to use it on stage :confused:
The DAC you just posted is an SMD. The internet is full of SMDs but there's no DIP!
I was hopping I could use any of the existent boards, like the open codec shield
Or the music shield for seeduino:
pYro_65:
So obviously 32Kb of flash ram won't work for me...The sad thing is that I already own 2 arduinos.
Should I go for the Maple then? Maple | LeafLabs
Maybe if I drop the word length to 16 bit...which is CD quality (not bad either), a sample would fit there! No?
