Wireless LED Lights controlled/synced with Midi
So I am a musician, I have an Elegoo 2560 Mega, I want to rig up LED light strips inside of Chinese Lanterns and have them synced with the music and strung around the room I will be playing. I could set up these lights by buying about 300 feet of ethernet cable and running a cable out to each light, but with the change of venue, it will become tedious to change lengths of cables and finding a way to surround each different room with these lanterns. Is there a way I could have each LED strip connect to my computer/board so that I could sync them with a small to no amount of latency?
Sure, use a simple 433 Tx unit at the master arduino, and a Rx unit at each slave arduino, send the pattern wirelessly and have each slave update it outputs.
Then you only need to run power out to each slave.
CrossRoads:
Thank you for the quick reply! So I would need 12 additional "slave" Arduino's to receive the signal from the master Arduino if I had 12 lights? I'm fairly new to the Arduino community so I need a dictionary of some sort lol.
