Wireless LED
I have a project were I have to wirelessly control 10 modules with one channel (LED) on each controller. I need them to be controlled by one arduino and be able to dim each module separately (so the input to the arduino is a POT or something (thats the least of my worries))
The LEDs Probably just be bright 5mm led so low current.
I had my eye on the 433mhz transmitters and receivers but I don't think you could have 10 channels going at once, also they probably not reliable.
But i need it as small and CHEAP as possible.
Thanks Ian
The 433 MHz modules, if equipped with reasonable antennas (17 cm straight wire) and error detecting encoding/decoding software like VirtualWire, are quite reliable and very cheap. It would be no problem to send 10 brightness values once a second or so to a remote LED controller.
so how would I code 10 channels
ianscott-arduino:
You would learn how to send a message using that hardware, and then write code to send a message containing ten values, and code to receive the ten values and output the corresponding brightness on each channel.
Try EasyTransfer Arduino Library « The Mind of Bill Porter. The download contains an example for using it with the VirtualWire library. Regarding reliability the EasyTransfer library also automagically performs checksumming of transferred data.
i kinda know how to use virtual wire sending one channel but ten i have no idea
ianscott-arduino:
You do not need 10 channels you only need to send a message that contains enough information so that only the module that is addressed responds to the message.
If the receiving Arduino controls all 10 LEDs, then the transmitting Arduino uses VirtualWire to send a single message (perhaps once every second) containing 10 bytes of information. Each byte contains one brightness value in the range 0-255, corresponding to LEDs 1-10.
I think what they are saying is
the transmitter sends a message with all 10 codes
all the receivers receive the whole message
receiver 1 acts on the 1st code
receiver 2 acts on the 2nd code
etc.
So each receiver's sketch is hard-coded to respond to only it's part of the whole message.
John
I've had better luck sending multiple messages with a different header (which is particular to the intended recvr) in each message. the 433MHz modules i've used ar AM and therefore subject to a lot of noise and backend arduinos don't always get the entire message packet. I've had a lot better luck using Nordic modules.
