I'm trying to implement Wireless M-Bus (Meter Bus) protocol with an RFM22.
EN 13757-4 specifies the following:
The total preamble (header + synchronisation) chip sequence for this mode shall be n×(01) 000111011010010110 with n ? 39.
and then
In Manchester coding, the chip sequence 000111 is invalid. But it is used near the end of the header to allow a receiver to detect the start of a new or a stronger transmission.
Now here is my problem:
I can't enable Manchester encoding in the RFM22 because I won't be able to set chips 000111 as a sync word.
And if I disable the Manchester encoding, the RFM22 assumes that the preamble starts with a 1, that is to say n×(10) instead of n×(01).
Any idea ?
