Hello
How can I transfer large files that may be 10 megabytes or more by using one of the wireless network sensor , for example the hc-12, hc-05 , esp and others. For information, the types of files are different, they may be audio files, video clips, photos, etc.
The work of the project is that I have a number of sender circuits and one receiver circuit using Arduino and wireless network sensor
Example:
Your topic was MOVED to its current forum category as it is more suitable than the original
Transfering large files You ought to look at dending and receiving devices have a bitrate hugh enough too fullfill Your time demands.
Reading datasheets will be useful.
After looking at a lot of sources, I have an idea how to do that, but is there a sensor that performs this role, or do you know a sensor that does that?
What is Your requirements for the time allowed to transmitt data? You better talk about transmitters and receivers. "Sensor" is a misleading word.
Forget UHF devices, its not legal just about everywhere to limit air time to 10%, so such large transfers will not really be possible.
For point to point devices then 2.4Ghz LoRa devices are a option, much faster than UHF devices and no real duty cycle limits;
For a 10Mbyte file such a transfer would take around 12minutes.
Transfer by WiFi would be far more practical.
What do you think of this sensor? Can I transfer large files to it? It works with zigbee technology, but the problem is that I do not have complete knowledge of networks, so I asked here.
I do not have a specific time. What time the file can be reached I am not interested in the time
Would you be prepared to wait a week for the files to transfer?
Is Your project just for fun, playing, without any specific purpose? Then any device would do as long as no laws are broken.
Given the application, which apparently is health related, you would do such file transfers either over WiFi or local network connections.
A hobby based Arduino approach using RF modules seems rather inappropriate.
Not a week, a few minutes might be enough time
Not for fun, but a college project for one of my friends..
Ah, so you do have a rough time in mind. Going back to your first post, you have a number of files exceeding 10 megs and you would like to transfer one 10MB file (or is it several 10MB files) in "a few" minutes.
Maybe a WiFi based solution as suggested by @srnet would best suit your application. Possibly something based around one of the Raspberry Pi boards?
Okey. Can You outline the text a bit? I feel pretty sure that will motivate more helpers to reply, maybe someone doing something like Your project.
The type of files you referenced would need to be transferred with out a single error, so you need a protocol that ensures each and every transmission is received with zero errors. The usual Arduino communication do NOT include any type of error detection or correction.
Good luck.
Indeed so.
One byte in the whole 10Mb could have a single bit which is the patient dead\alive flag.
Is such a sensor sufficient for the purpose?
If it only duplicates what is the usual protocol for Arduino serial communications, definitely NOT. There is normally NO error detection and retransmission. You would have to add that capability.
