wireless pipeline leakage detector system
I intend to build aa wireless pipeline leakage detector system. I am looking into using arduino interface with hydrophone and wireless sensor will be responsible for transmitting the signal since the system will be submerged into the pipeline inoder to detect and localize the leakage.please I need help with
1.is there any library for inter
Facing hydrophone(piezo sensor with arduino)
2.whats d best method I could use to achieve a better resullt in terms of leak detection and localization of the leakage
Presumably you are listening for some frequency or characteristic noise that a leak makes. You will need FFT or DSP processing. The 8 bit Arduinos won't be able to do much. The Teensy has some DSP libraries but they probably don't do what you want.
This sounds like an academic project. What does your teacher want you to use?
