Wireless Programming with RF (nRF24L01+)
Edit/Update April 22nd:
Restating my problem:
I am building a device which I have no way to physically interface with, once activated. It is very probable that I will be improving/modifying the software side of things, as time goes on. I want a way to change the code running on the Arduino.
Current setup I am considering:
a nRF24L01+ with a dedicated Arduino Pro Mini(a) for communication (this breakoutboard: http://iteadstudio.com/store/index.php?main_page=product_info&cPath=7&products_id=53) and an additional Arduino Pro Mini(b) for logic.
Arduino a runs software which enables it to forward messages between Arduino b and RF module. Arduino b handles the rest of the logic.
The sketch on Arduino a would be permanent, and I could reprogram Arduino b via Arduino a.
Questions:
Well. Actually. I don't even know where to start. I plan on ordering the parts next week and start tinkering, but I would really apreceate some more feedback
a) Is this feasible?
b) Is there any other/better way of doing this?
c) How would you go about it - are there any similar projects you know of?
this is my original post:
Is it possible to use the nRF24L01+ chip to send sketches to the arduino?
Using one of these breakout boards as the receiver:
http://iteadstudio.com/store/index.php?main_page=product_info&cPath=7&products_id=53&zenid=jpdvhl54i61124np272uj4ue62
And this here (in combination with one of the breakouts) as sender:
I feel like I might need an additional controller to read the signal from the RF module and then output a serial signal to the Arduino. Ideally I would not want to use an additional controller. Is it possible?
I'd appreceate suggestions and comments
Thanks
p.
let me ask my question in a more specific way.
the nRF24L01+ connects to the Arduino, and is controlled by the Arduino via ISP. Is it theoretically possible to upload a sketch to that Arduino via that ISP connection?
Hmm, not sure how the nRF works but for it to act like an ICSP programmer, it would have to be able to suddenly become an SPI "master", there'd have to be some kind of GPIO output built into the nRF which can be tied to RESET. Doubtful that this is feasible but I haven't read the datasheet for the chip yet. I intend to use this for a project in the near future though.
If this chip can only communicate via SPI then you couldn't use it to do normal serial USART arduino bootloader-style programming, so that's out.
nRF24L01+ only communicates as an SPI slave. It has no master pin. It also does not have available GPIO pins.
Nordic does have another module, the nRF24LE1F which according to its datasheet, can act as both an SPI slave or SPI master. However I don't know anyone that sells a complete module with that IC on it. Most of what you'll find are the 24L01+ ones.
Their nRF24LU1+ can also act as an SPI master and slave and also has USB built in, though I believe that's just a USB device, not host.
I have used the regular 24L01+ extensively in various projects. They're quite fun to play with.
ok. so I want to build wireless re-programmable sensor nodes, and I really would like to use the 24L01 for the multiple pipes.
could I use the 24LO1+ to communicate with two ATmega328 simultaniously?
ATmega #1 just sits there most of the time, while ATmega #2 does all the logic of the sensor module.
Except when I send a specific command, which activates ATmega #1.
I then use the ATmega #1 to reprogramme ATmega #2 ?
Ahhh... I am way out of my water here. Does this make any sense?
Any other suggestions on how to create ~5 sensor nodes, which can communicate with each other as well as with a central hub and which I can remotely upload sketches to?
What is the end result which you're trying to achieve which you think will need wireless sketch uploads? I doubt that is feasible, but perhaps there is another way to achieve your end result.
fkeel:
Sounds feasible. You'd connect the rf24l01+ to the master atmega and connect that to the slave atmega via the hardware serial ports, and also connect a GPIO from the master to the slave atmega's reset pin. Then the master can reset the slave and program a new sketch into it, receiving the sketch via the rf24l01+.
You'd need to create a serial protocol so that the slave can send and receive messages via the rf24l01+ from the master atmega.
this is the edit of my original post. just reposting instead you skipped my first post and went directly to the bottom.
Questions:
basically I am planning on doing what dhunt suggested. I just would really like some more opinions ....
Any comments or thoughts are highly apreceated
Cheers
p.
The rest of the logic of reprogramming itself? When you reset Arduino b to get to the point where you can load the new code, how do you propose to get that code from the radio?
no, sry. that was imprecisely formulated.
Arduino A, forwards data between Arduino B and RF module. Arduino A also is fully in charge of reprogramming Arduino B.
Arduino B takes care of the logic such as, when to log information, when to send it, when to give feedback and all the other issues in regards with my actual application.
Is this feasible? As in, is this a problem someone with mediocre programming skills, but, lots of patience and enthusiasm can realistically solve within a couple of weeks?
p.
fkeel:
It sounds feasible to me, although the combination of 'mediocre programming skills' plus 'within a couple of weeks' might be tricky.
Please delete this post. It has wasted 1,000s of people's valuable time.
Please don't respond to posts if you don't know the answer.
cmayer777:
How do you know?
Why are you wasting your own time on a 5-years dead Thread?
...R
Simple nRF24L01+ Tutorial
2 entire posts and you're already playing forum cop? Seriously? If you don't care for a thread, just move on. This is what's known as a self-refuting comment, a comment that complains about pointless comments, itself a pointless comment.
