Wireless PS3 controller + Relays
Hello all, I am after some guidance please. I’m using the PS3 wireless Bluetooth code as at the end of this post and I want to be able to control relays dependant on what relay I choose.
The finishing goal is for my cars hydraulic suspension system to be controlled wirelessly from near the car where I can raise or lower the car at my command.
For this I have a 7 core cable that controls the 4 corners, lift, drop and the 12v supply.
For the testing purposes I want the PlayStation 3 wireless controller to lift all 4 corners up with an up button and drop all 4 corners with the down button on the PS3 controller. Once I have the code figured out I can then adjust each button to do a separate command.
Now I added to the up button command a “digitalWrite(2,HIGH);” so it sent voltage to the relay coil to switch the relay. The trouble is it kept it on high.
So I added at the end of the commands
else {
digitalWrite(2,LOW);
And what happens is the up command activated the relay and opens it straight after which is great. However when I press and hold the up button on the PS3 controller it won’t keep the relay closed.
Basically I want the PS3 controllers buttons to work as momentary switches that stay switched as long as I hold the button and off as soon as I let go.
Any help would be greatly appreciated.
I know I can get rid of the PlayStation move controller section of the code as it won’t be used
The code I am using is this:
 Example sketch for the PS3 Bluetooth library - developed by Kristian Lauszus
 For more information visit my blog: http://blog.tkjelectronics.dk/ or
 send me an e-mail:  kristianl@tkjelectronics.com
#include <PS3BT.h>
#include <usbhub.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
USB Usb;
//USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
PS3BT PS3(&Btd); // This will just create the instance
//PS3BT PS3(&Btd, 0x00, 0x15, 0x83, 0x3D, 0x0A, 0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
bool printTemperature, printAngle;
#if !defined(__MIPSEL__)
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while (1); //halt
  Serial.print(F("\r\nPS3 Bluetooth Library Started"));
  Usb.Task();
  if (PS3.PS3Connected || PS3.PS3NavigationConnected) {
    if (PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
      Serial.print(F("\r\nLeftHatX: "));
      Serial.print(PS3.getAnalogHat(LeftHatX));
      Serial.print(F("\tLeftHatY: "));
      Serial.print(PS3.getAnalogHat(LeftHatY));
      if (PS3.PS3Connected) { // The Navigation controller only have one joystick
        Serial.print(F("\tRightHatX: "));
        Serial.print(PS3.getAnalogHat(RightHatX));
        Serial.print(F("\tRightHatY: "));
        Serial.print(PS3.getAnalogHat(RightHatY));
    // Analog button values can be read from almost all buttons
    if (PS3.getAnalogButton(L2) || PS3.getAnalogButton(R2)) {
      Serial.print(F("\r\nL2: "));
      Serial.print(PS3.getAnalogButton(L2));
        Serial.print(F("\tR2: "));
        Serial.print(PS3.getAnalogButton(R2));
    if (PS3.getButtonClick(PS)) {
      Serial.print(F("\r\nPS"));
      PS3.disconnect();
    else {
      if (PS3.getButtonClick(TRIANGLE)) {
        Serial.print(F("\r\nTraingle"));
        PS3.setRumbleOn(RumbleLow);
      if (PS3.getButtonClick(CIRCLE)) {
        Serial.print(F("\r\nCircle"));
        PS3.setRumbleOn(RumbleHigh);
      if (PS3.getButtonClick(CROSS))
        Serial.print(F("\r\nCross"));
      if (PS3.getButtonClick(SQUARE))
        Serial.print(F("\r\nSquare"));
      if (PS3.getButtonClick(UP)) {
        Serial.print(F("\r\nUp"));
          PS3.setLedOff();
          PS3.setLedOn(LED4);
      if (PS3.getButtonClick(RIGHT)) {
        Serial.print(F("\r\nRight"));
          PS3.setLedOff();
          PS3.setLedOn(LED1);
      if (PS3.getButtonClick(DOWN)) {
        Serial.print(F("\r\nDown"));
          PS3.setLedOff();
          PS3.setLedOn(LED2);
      if (PS3.getButtonClick(LEFT)) {
        Serial.print(F("\r\nLeft"));
          PS3.setLedOff();
          PS3.setLedOn(LED3);
      if (PS3.getButtonClick(L1))
        Serial.print(F("\r\nL1"));
      if (PS3.getButtonClick(L3))
        Serial.print(F("\r\nL3"));
      if (PS3.getButtonClick(R1))
        Serial.print(F("\r\nR1"));
      if (PS3.getButtonClick(R3))
        Serial.print(F("\r\nR3"));
      if (PS3.getButtonClick(SELECT)) {
        Serial.print(F("\r\nSelect - "));
        PS3.printStatusString();
      if (PS3.getButtonClick(START)) {
        Serial.print(F("\r\nStart"));
        printAngle = !printAngle;
#if 0 // Set this to 1 in order to see the angle of the controller
    if (printAngle) {
      Serial.print(F("\r\nPitch: "));
      Serial.print(PS3.getAngle(Pitch));
      Serial.print(F("\tRoll: "));
      Serial.print(PS3.getAngle(Roll));
#endif
#if 0 // Set this to 1 in order to enable support for the Playstation Move controller
  else if (PS3.PS3MoveConnected) {
    if (PS3.getAnalogButton(T)) {
      Serial.print(F("\r\nT: "));
      Serial.print(PS3.getAnalogButton(T));
      PS3.disconnect();
    else {
        Serial.print(F("\r\nSelect"));
        printTemperature = !printTemperature;
        Serial.print(F("\r\nTriangle"));
        PS3.moveSetBulb(Red);
        PS3.moveSetBulb(Green);
      if (PS3.getButtonClick(SQUARE)) {
        PS3.moveSetBulb(Blue);
      if (PS3.getButtonClick(CROSS)) {
        PS3.moveSetBulb(Yellow);
      if (PS3.getButtonClick(MOVE)) {
        PS3.moveSetBulb(Off);
        Serial.print(F("\r\nMove"));
        Serial.print(F(" - "));
    if (printAngle) {
    else if (printTemperature) {
      Serial.print(F("\r\nTemperature: "));
      Serial.print(PS3.getTemperature());
#endif
[\CODE]
Use code tags.
Get rid of commented-out code before you post.
HTH
Apologies. Sorted now
