wireless push button
what is wrong with my program, error in compiling both transmitter and receiver..
TRANSMITTER
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); //RX, TX
#define P1 8
#define P2 3
  pinMode(P1, INPUT);
  pinMode(P2, INPUT);
  mySerial.begin(9600);
  int buttonState = digitalRead(P1);
  int buttonState1 = digitalRead(P2);
  if(buttonState == 1){//if button is down
    mySerial.println(1234);//send unique code to the receiver in this case 1234
    if(buttonState1 == 1{
RECEIVER
SoftwareSerial mySerial(10, 11); // RX, TX
#define L1 2
#define L2 3
unsigned long last = millis();//set timer
  pinMode(L1, OUTPUT);
  pinMode(L2, OUTPUT);
  boolean ledState = digitalRead(L1);//check if the LED is turned on or off. Returns 1 or 0
  boolean ledState1 = digitalRead(L2);
  if(mySerial.available() > 1){
    int input = mySerial.parseInt();//read serial input and convert to integer (-32,768 to 32,767)
    if(millis() - last > 250){//if time now is 250 milliseconds greater than last time
      if(ledState == 0 && input == 1234){//if LED is off and button code is ok
          digitalWrite(L1, HIGH);
      }else if(ledState == 1 && input == 1234){//if LED is on and button code is ok
          digitalWrite(L1, LOW);
          if(ledState1 == 0 && input == 1234){//if LED is off and button code is ok
          digitalWrite(L2, HIGH);
          } else if (ledState1 == 1  && input == 1234){
        digitalWrite(L2,LOW);
    mySerial.flush();//clear the serial buffer for unwanted inputs
    last = millis();//reset timer
  delay(20);//delay little for better serial communication
Your codes are slightly adjusted to balance the {} braces and to come out from compilation error.
Sender codes:
#define P1 8
#define P2 3
  pinMode(P1, INPUT);
  pinMode(P2, INPUT);
  if (buttonState == 1)
  { //if button is down
Receiver Codes:
#define L1 2
#define L2 3
  if (mySerial.available() > 1)
    if (millis() - last > 250)
    { //if time now is 250 milliseconds greater than last time
      if (ledState == 0 && input == 1234)
      { //if LED is off and button code is ok
      else if (ledState == 1 && input == 1234)
      { //if LED is on and button code is ok
      if (ledState1 == 0 && input == 1234)
        digitalWrite(L2, LOW);
how to put it right?
beginners123:
Upload and check the result, please.
I'm keen to hear from @GolamMostafa why he or she commented part of OP's code away- I suppose that's one way of fixing a compiler error, just rem it out.
This code compiles and keeps OP's logic intact. Added 1x ) and 2x }:
#define P1 8
#define P2 3
  pinMode(P1, INPUT);
  pinMode(P2, INPUT);
      if (buttonState1 == 1)
neiklot:
That part has appeared to me as redundant; however, the OP may keep it if he thinks it is needed for his sketch.
GolamMostafa:
Did you perchance miss the "1" in the second "if"?
      if (buttonState1 == 1) //buttonState1 not buttonstate
neiklot:
Exactly! I misread and saying now that 'buttonState' and 'buttonState1' are different.
how to add another push button and led what is the code?
