please help me with my project how to put a buzzer and indicating led light to the receiver this is my codes please help me with these
these are my codes i got it from youtube
/*By Roee Bloch - Version 4
* This includes: Latch Mode, Momentary Mode (selected by A5 input), and also feedback to Transmitter that the Receiver got transmission OK - by LED on Transmitter
* Controls 4 logic output at 2 modes: Latch (each press change output ON/OFF), Momentary (output on just when button is pressed)
*HC-12 Moule Transciever Same code is for Transmitter and Receiver, setup through A4 Input
*Tested on Arduino Nano
* This SW is for Transmitter & Receiver, the choise is done by reading A4 & A5 inputs (analog inputs)
* A4=1=> TX, A4=0=>RX
* A5=1=>LATCH (Default mode), A5=0=>Momentary the stting now is via variable latch_logic if 1=> latch if 0=> momentary
* NANO connections to HC-12 As follows:
* ARDUINO NANO HC-12-MODULE
* _________________________________________________________________________
* 5V -> 1N4148 Anode, 1N4148 catode -> HC-12/Pin-1 (VCC)
* GND -------> GND
* D11 -------> RXD
* D10 -------> TXD
* NANO (TX MODULE) NANO (RX MODULE)
* ______________________ ________________________________
* D2 --> SW --> GND (SW1) A4 --> GND
* D3 --> SW --> GND (SW2) D2 --> OUTPUT 1
* D4 --> SW --> GND (SW3) D3 --> OUTPUT 2
* D5 --> SW --> GND (SW4) D4 --> OUTPUT 3
* D5 --> OUTPUT 4
* FEEDBACK back will light Led on Trnasmitter for 100mS
* See connection Diagram here:
* https://goo.gl/photos/qog8gWPKpSDPgZen7
#define P1 2
#define P2 3
#define P3 4
#define P4 5
#define F1 6 // feedback back to transmitter
//#define latch_logic 1 // if 1 then latch if 0 momentary
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
char latch; // , if latch=1 then Latch
int read_A4, read_A5, i, read_P1, read_P2, read_P3, read_P4;
int TX_CODE, RX_READ, mode, TX_CODE_OLD; //if mode= 1 then TX
int RP1, RP2, RP3, RP4;
volatile byte SW1 = 0, SW2 = 0, SW3 = 0, SW4 = 0;
boolean S1, S2, S3, S4;
byte TEST;
char TXTOSEND,feedback;
int FLAG=1,latch_logic;
mySerial.begin(9600);
Serial.println("Hello HC-12 TX and RX SW, A4-Low=TX A4-HIGH=RX A5-LOW=Momemtary A5-HIGH=LATCH");
// mySerial.println("Hello HC-12 TX and RX SW, A4-Low=TX A4-HIGH=RX A5-LOW=Momemtary A5-HIGH=LATCH");
// This is for internal pull ups resistors on A4 and A5 Inputs
pinMode(A4, INPUT_PULLUP);
pinMode(A5, INPUT_PULLUP);
read_A4 = analogRead(A4);
read_A5 = analogRead(A5);
if ((read_A4) > 500) {
mode = 1;
Serial.println("TX Mode");
mode = 0;
Serial.println("RX Mode");
if ((read_A5) > 500) {
latch = 1;
latch_logic=latch;
Serial.println("LATCH Mode");
latch = 0;
latch_logic=latch;
Serial.println("Momentary Mode");
if (mode == 1) // TX
pinMode(P1, INPUT); // set pin to input
digitalWrite(P1, HIGH); // turn on pullup resistors
pinMode(P2, INPUT); // set pin to input
digitalWrite(P2, HIGH); // turn on pullup resistors
pinMode(P3, INPUT); // set pin to input
digitalWrite(P3, HIGH); // turn on pullup resistors
pinMode(P4, INPUT); // set pin to input
digitalWrite(P4, HIGH); // turn on pullup resistors
pinMode(F1, OUTPUT); // set pin to input
digitalWrite(F1, LOW);
pinMode(P1, OUTPUT); // set pin to input
digitalWrite(P1, LOW); // turn on pullup resistors
pinMode(P2, OUTPUT); // set pin to input
digitalWrite(P2, LOW); // turn on pullup resistors
pinMode(P3, OUTPUT); // set pin to input
digitalWrite(P3, LOW); // turn on pullup resistors
pinMode(P4, OUTPUT); // set pin to input
digitalWrite(P4, LOW); // turn on pullup resistors
if (mode == 1) //TX Mode
TX_MODE();
RX_MODE();
void TX_MODE()
while (1)
read_P1 = digitalRead(P1);
read_P2 = digitalRead(P2);
read_P3 = digitalRead(P3);
read_P4 = digitalRead(P4);
TX_CODE = 64 + (read_P1 * 1) + (read_P2 * 2) + (read_P3 * 4) + (read_P4 * 8); // converting TX to one char
TXTOSEND = TX_CODE; // conver to char for sending OK
if (FLAG==0) // skip first time on FLAG=1
if (latch==1)
if ((TX_CODE != TX_CODE_OLD)&&(latch_logic==1)) // transmit only on change
Serial.print(TX_CODE, BIN);
mySerial.print(TXTOSEND);
delay(100);
TX_CODE_OLD = TX_CODE;
delay(100);
else FLAG=0;
feedback=mySerial.read();
if (feedback=='R')
Serial.println("Data_Sent_OK"); // feedback to serial port
digitalWrite(F1, HIGH); // Ligjt Led Back on Transmitter
delay(80);
void RX_MODE()
while (1)
if (mySerial.available()) {
// read the incoming byte:
RX_READ = mySerial.read();
TEST = RX_READ;
RP1 = (TEST) & (1);
RP2 = (TEST) & (2);
RP3 = (TEST) & (4);
RP4 = (TEST) & (8);
mySerial.flush();
// When button is pressed (logic 0) toggling the apropriate LED Latch mode only
if ((latch==1)&&(latch_logic==1))
if (RP1 == 0) SW1 = ~(SW1);
if (RP2 == 0) SW2 = ~(SW2);
if (RP3 == 0) SW3 = ~(SW3);
if (RP4 == 0) SW4 = ~(SW4);
mySerial.print("R"); // This is feedback back to transmitter
else // Momentary mode ON only when button is pressed continously
if (RP1 == 0)
SW1 = 1;
} else SW1=0;
if (RP2 == 0)
SW2 = 1;
} else SW2=0;
if (RP3 == 0)
SW3 = 1;
} else SW3=0;
if (RP4 == 0)
SW4 = 1;
} else SW4=0;
//convert to bit for Digital-Out from Arduino
S1= SW1 & 1;
S2= SW2 & 1;
S3= SW3 & 1;
S4= SW4 & 1;
digitalWrite(P1, S1);
digitalWrite(P2, S2);
digitalWrite(P3, S3);
digitalWrite(P4, S4);
delay(100);
Serial.print("S1=");
Serial.print(SW1);
Serial.print(" S2=");
Serial.print(SW2);
Serial.print(" S3=");
Serial.print(SW3);
Serial.print(" S4=");
Serial.println(SW4);
