This is a RC Model Submarine, this section is for wireless diagnostic !
I need help on how to make my wireless communication working:
Wireless transmission by APC220 between 2 Arduino MEGA,
Operations:
I need, when the data arrive (2 numbers for prefix and 3 numbers for data), to be treated corresponding to the header value
for exemple: 01200
- No treatement at all !
- No variables printed beside menuItems, for example ( gite 200)
- The program is always on serial receive, and it is not possible to navigate through the menus.
- When navigation will be possible, i need a little temporisation between menu items when navigating
- Do the Serial Buffer is cleaned automatically ?
Many thanks for who can help me
Regards
(Some parts of menus have been removed (9500 characters maximum on forum)
#include <MenuBackend.h>
#include <LiquidCrystal.h>
int secoursTR = 0, periscopeTR = 0, lampeTR = 0, sigsurfaceTR = 0, ledTR = 1, cdebarresavTR = 0, tiltbarresavTR = 0, cdeevballastTR = 0, powerTR = 0;
int prefix = 0,value = 0;
int sigairtankTR = 0, emergencyTR = 0, sigtempmotTR = 0, sigtempcompTR = 0, ppmbarresTR = 0;
int lestTR = 0, cdecaisseavTR = 0, cdecaissearTR = 0, sigballastfullTR = 0, waterTR = 0, compgTR = 0, compdTR = 0, airpowerTR = 0;
int cdewatpumpTR = 0, cdeinvpumpTR = 0, rollvar = 0, ballastinTR = 0, ballastoutTR = 0;
int opentrapTR=0; // Temporisation de vidange du ballast
int menugval = 0, validval = 0, menudval = 0, outval = 0, menuval = 0; // Definition des variables de pilotage du menu
long voie1TR = 0, voie3TR= 0, voie5TR = 0, voie6TR = 0, voie7TR = 0;
int pitchTR = 0, rollTR = 0, sigprofTR = 0, siglampeTR = 0;
int timetorpTR = 0 , timemissTR = 0 , maxtempTR = 0 , maxprofTR = 0 , sinkadjustTR = 0;
int pressureTR = 0;
const int pressurepin = 8;
int myStr[5];
int i = 0;
int touche = 0, ad0val = 0;
const int ad0pin = 0;
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
MenuBackend menu = MenuBackend(menuUseEvent,menuChangeEvent);
MenuItem systeme = MenuItem("Systeme");
MenuItem serial = MenuItem("View Serial", value);
MenuItem tester = MenuItem("TESTER");
MenuItem roll = MenuItem("Gite " , rollTR);
MenuItem pitch = MenuItem("Pitch " , pitchTR);
MenuItem sigtempmot = MenuItem("Temp Moteur " ,sigtempmotTR);
MenuItem sigtempcomp = MenuItem("Temp Compr " , sigtempcompTR);
MenuItem sigprof = MenuItem("Profondeur " , sigprofTR);
MenuItem sigsurface = MenuItem("Capt Surf " , sigsurfaceTR);
MenuItem lampe = MenuItem("Lampe " , siglampeTR);
MenuItem secours = MenuItem("Ballon " , secoursTR);
MenuItem periscope = MenuItem("Periscope " , periscopeTR);
MenuItem led = MenuItem("Led: " , ledTR);
MenuItem cdebarresav = MenuItem("Bar AV R/S " , cdebarresavTR);
MenuItem tiltbarresav = MenuItem("Bar AV Tilt" , tiltbarresavTR);
MenuItem cdeevballast = MenuItem("EV Ballast " , cdeevballastTR);
MenuItem reglages = MenuItem("REGLAGES");
MenuItem timetorp = MenuItem("Duree Torp" , timetorpTR);
MenuItem timemiss = MenuItem("duree miss" , timemissTR);
MenuItem maxtemp = MenuItem("Temp Max" , maxtempTR);
MenuItem maxprof = MenuItem("Prof. max" , maxprofTR);
MenuItem sinkadjust = MenuItem("Cal. Plongee" , sinkadjustTR);
Serial1.begin(9600);
lcd.begin(16,2);
menuSetup();
lcd.setCursor(0,0);
lcd.print("SUBSOFT V1.04");
establishContact(); // send a byte to establish contact until receiver responds
prefix = 0;
if (Serial1.available() > 0) { // get incoming byte:
delay(5);
i=1;
while(i<6){
myStr[i] = Serial1.read();
i++;
// Serial1.print(myStr[5]);
lcd.setCursor(1,1);
lcd.print(myStr[5]);
prefix = myStr[1] && myStr[2];
value = myStr[3] && myStr[4] && myStr[5];
lcd.setCursor(6,1);
lcd.print(value);
delay (200);
if (prefix == 'AA')
lcd.setCursor (14,0);
lcd.print("OK");
lcd.setCursor(14,0);
lcd.print(" ");
prefix = 00 ;
value = 000;
lcd.print("KO");
delay (100);
switch (prefix)
case 01:
rollTR = value;
case 02:
pitchTR = value;
case 03:
sigtempmotTR = value;
case 04:
sigtempcompTR = value;
case 05:
sigprofTR = value;
case 06:
sigsurfaceTR = value;
lcd.setCursor(0,1);
ad0val = analogRead(ad0pin);
if (ad0val >= 110 && ad0val <= 135)
touche = 3; // Touche UP
menu.moveUp();
//lcd.setCursor(0,0);
//lcd.print("Up");
else if (ad0val >= 290 && ad0val <= 315)
touche = 4; // Touche DOWN
menu.moveDown();
//lcd.print("Down");
else if (ad0val >= 465 && ad0val <= 485)
touche = 1; // touche LEFT
menu.moveLeft();
//lcd.print("left");
else if (ad0val >= 0 && ad0val <= 150)
touche = 2; // touche RIGHT
menu.moveRight();
//lcd.print("Right");
else if (ad0val >= 700 && ad0val <= 730)
touche = 0; // touche SELECT
menu.use();
//lcd.print("Use");
void menuSetup()
menu.getRoot().add(tester);
//setup the tester menu item
//we want a left movement to pint to tester from anywhere
reglages.addLeft(tester);
tester.addLeft(tester);
tester.addBefore(systeme);
tester.addAfter(reglages);
reglages.addAfter(systeme);
systeme.addAfter(tester);
reglages.addBefore(tester);
tester.addRight(roll);
roll.addBefore(emergency);
roll.addAfter(pitch);
pitch.addAfter(sigtempmot);
sigtempmot.addAfter(sigtempcomp);
sigtempcomp.addAfter(sigsurface);
sigsurface.addAfter(sigprof);
sigprof.addAfter(lampe);
lampe.addAfter(periscope);
roll.addLeft(tester);
pitch.addLeft(tester);
sigtempmot.addLeft(tester);
sigtempcomp.addLeft(tester);
sigsurface.addLeft(tester);
sigprof.addLeft(tester);
lampe.addLeft(tester);
periscope.addLeft(tester);
secours.addLeft(tester);
led.addLeft(tester);
cdebarresav.addLeft(tester);
tiltbarresav.addLeft(tester);
cdeevballast.addLeft(tester);
power.addLeft(tester);
void establishContact() {
while (Serial1.available() <= 0) {
Serial1.print('AA', BYTE); // send a capital A
delay(300);
