Grumpy_Mike:
That makes no sense at all, you have used the wrong word, "temporary" means not permanent or efermal.
Ok ok, i just connected my amp and a speaker, it kills my hears!
But it's there
Grumpy_Mike:
Have you done this?
I assume it is in the setup function. You should use a frequency of over 30KHz.
How do i do that?
Thanks for your time and support
Grumpy_Mike:
For changing the PWM frequency see this
Arduino Playground - HomePage
I've tried every value possible and no solution, are you sure this will work?
void setPwmFrequency(int pin, int divisor) {
byte mode;
if(pin == 5 || pin == 6 || pin == 9 || pin == 10) {
switch(divisor) {
case 1:
mode = 0x01;
case 8:
mode = 0x02;
case 64:
mode = 0x03;
case 256:
mode = 0x04;
case 1024:
mode = 0x05;
default:
return;
if(pin == 5 || pin == 6) {
TCCR0B = TCCR0B & 0b11111000 | mode;
else {
TCCR1B = TCCR1B & 0b11111000 | mode;
else if(pin == 3 || pin == 11) {
switch(divisor) {
case 1:
mode = 0x01;
case 8:
mode = 0x02;
case 32:
mode = 0x03;
case 64:
mode = 0x04;
case 128:
mode = 0x05;
case 256:
mode = 0x06;
case 1024:
mode = 0x7;
default:
return;
TCCR2B = TCCR2B & 0b11111000 | mode;
pinMode(11, OUTPUT);
setPwmFrequency(11, 1);
void loop(){
int val = analogRead(A0);
analogWrite(11, val);
Come on you know the score by now, code tags please.
Thanks for changing the post.
Now when you say it doesn't work what do you mean:-
- There is no longer any sound out of it.
or
- I can not perceive any improvement in the sound?
