Wireless Transmission of EMG signals with Iteadstudio bt shield
I’m finding it extremely difficult to transmit EMG signal "wirelessly " using my ITEADSTUDIO bt shield v2.2. It works properly with USB.
This is the code for the EMG-SHIELD:
Is there anything I could do on bt shield part?
/* Demo program for:                                      */
/*    Board: SHIELD-EKG/EMG + Olimexino328                */
/*  Manufacture: OLIMEX                                   */
/*  COPYRIGHT (C) 2012                                    */
/*  Designed by:  Penko Todorov Bozhkov                   */
/*   Module Name:   Sketch                                */
/*   File   Name:   ShieldEkgEmgDemo.ino                  */
/*   Revision:  Rev.A                                     */
/*    -> Added is suppport for all Arduino boards.        */
/*       This code could be recompiled for all of them!   */
/*   Date: 19.12.2012                                     */
/*   Built with Arduino C/C++ Compiler, version: 1.0.3    */
Purpose of this programme is to give you an easy way to
connect Olimexino328 to ElectricGuru(TM), see:
https://www.olimex.com/Products/EEG/OpenEEG/EEG-SMT/resources/ElecGuru40.zip
where you'll be able to observe yours own EKG or EMG signal.
It is based on:
* ModularEEG firmware for one-way transmission, v0.5.4-p2
* Copyright (c) 2002-2003, Joerg Hansmann, Jim Peters, Andreas Robinson
* License: GNU General Public License (GPL) v2
For proper communication packet format given below have to be supported:
////////// Packet Format Version 2 ////////////
// 17-byte packets are transmitted from Olimexino328 at 256Hz,
// using 1 start bit, 8 data bits, 1 stop bit, no parity, 57600 bits per second.
// Minimial transmission speed is 256Hz * sizeof(Olimexino328_packet) * 10 = 43520 bps.
struct Olimexino328_packet
  uint8_t	sync0;		// = 0xa5
  uint8_t	sync1;		// = 0x5a
  uint8_t	version;	// = 2 (packet version)
  uint8_t	count;		// packet counter. Increases by 1 each packet.
  uint16_t	data[6];	// 10-bit sample (= 0 - 1023) in big endian (Motorola) format.
  uint8_t	switches;	// State of PD5 to PD2, in bits 3 to 0.
#include <compat/deprecated.h>
#include <FlexiTimer2.h>
//http://www.arduino.cc/playground/Main/FlexiTimer2
// All definitions
#define NUMCHANNELS 6
#define HEADERLEN 4
#define PACKETLEN (NUMCHANNELS * 2 + HEADERLEN + 1)
#define SAMPFREQ 256                      // ADC sampling rate 256
#define TIMER2VAL (1024/(SAMPFREQ))       // Set 256Hz sampling frequency
#define LED1  13
#define CAL_SIG 9
// Global constants and variables
volatile unsigned char TXBuf[PACKETLEN];  //The transmission packet
volatile unsigned char TXIndex;           //Next byte to write in the transmission packet.
volatile unsigned char CurrentCh;         //Current channel being sampled.
volatile unsigned char counter = 0;	  //Additional divider used to generate CAL_SIG
volatile unsigned int ADC_Value = 0;	  //ADC current value
// Functions
/*  Function name: Toggle_LED1                      */
/*  Parameters                                      */
/*    Input   :  No	                            */
/*    Output  :  No                                 */
/*    Action: Switches-over LED1.                   */
void Toggle_LED1(void)
 if((digitalRead(LED1))==HIGH){ digitalWrite(LED1,LOW); }
 else{ digitalWrite(LED1,HIGH); }
/*  Function name: toggle_GAL_SIG                   */
/*  Parameters                                      */
/*    Input   :  No	                            */
/*    Output  :  No                                 */
/*    Action: Switches-over GAL_SIG.                */
void toggle_GAL_SIG(void)
 if(digitalRead(CAL_SIG) == HIGH){ digitalWrite(CAL_SIG, LOW);
 else{ digitalWrite(CAL_SIG, HIGH);
/*  Function name: setup                            */
/*  Parameters                                      */
/*    Input   :  No	                            */
/*    Output  :  No                                 */
/*    Action: Initializes all peripherals           */
 noInterrupts();  // Disable all interrupts before initialization
 // LED1
 pinMode(LED1, OUTPUT);  //Setup LED1 direction
 digitalWrite(LED1,LOW); //Setup LED1 state
 pinMode(CAL_SIG, OUTPUT);
 //Write packet header and footer
 TXBuf[0] = 0xa5;    //Sync 0
 TXBuf[1] = 0x5a;    //Sync 1
 TXBuf[2] = 2;       //Protocol version
 TXBuf[3] = 0;       //Packet counter
 TXBuf[4] = 0x02;    //CH1 High Byte
 TXBuf[5] = 0x00;    //CH1 Low Byte
 TXBuf[6] = 0x02;    //CH2 High Byte
 TXBuf[7] = 0x00;    //CH2 Low Byte
 TXBuf[8] = 0x02;    //CH3 High Byte
 TXBuf[9] = 0x00;    //CH3 Low Byte
 TXBuf[10] = 0x02;   //CH4 High Byte
 TXBuf[11] = 0x00;   //CH4 Low Byte
 TXBuf[12] = 0x02;   //CH5 High Byte
 TXBuf[13] = 0x00;   //CH5 Low Byte
 TXBuf[14] = 0x02;   //CH6 High Byte
 TXBuf[15] = 0x00;   //CH6 Low Byte
 TXBuf[2 * NUMCHANNELS + HEADERLEN] =  0x01;	// Switches state
 // Timer2
 // Timer2 is used to setup the analag channels sampling frequency and packet update.
 // Whenever interrupt occures, the current read packet is sent to the PC
 // In addition the CAL_SIG is generated as well, so Timer1 is not required in this case!
 FlexiTimer2::set(TIMER2VAL, Timer2_Overflow_ISR);
 FlexiTimer2::start();
 // Serial Port
 Serial.begin(57600);
 //Set speed to 57600 bps
 // MCU sleep mode = idle.
 //outb(MCUCR,(inp(MCUCR) | (1<<SE)) & (~(1<<SM0) | ~(1<<SM1) | ~(1<<SM2)));
 interrupts();  // Enable all interrupts after initialization has been completed
/*  Function name: Timer2_Overflow_ISR              */
/*  Parameters                                      */
/*    Input   :  No	                            */
/*    Output  :  No                                 */
/*    Action: Determines ADC sampling frequency.    */
void Timer2_Overflow_ISR()
  // Toggle LED1 with ADC sampling frequency /2
  Toggle_LED1();
  //Read the 6 ADC inputs and store current values in Packet
  for(CurrentCh=0;CurrentCh<6;CurrentCh++)
    ADC_Value = analogRead(CurrentCh);
    TXBuf[((2*CurrentCh) + HEADERLEN)] = ((unsigned char)((ADC_Value & 0xFF00) >> 8));	// Write High Byte
    TXBuf[((2*CurrentCh) + HEADERLEN + 1)] = ((unsigned char)(ADC_Value & 0x00FF));	// Write Low Byte
  // Send Packet
  for(TXIndex=0;TXIndex<17;TXIndex++)
    Serial.write(TXBuf[TXIndex]);
  // Increment the packet counter
  TXBuf[3]++;
  // Generate the CAL_SIGnal
  counter++;		// increment the devider counter
  if(counter == 12){	// 250/12/2 = 10.4Hz ->Toggle frequency
    counter = 0;
    toggle_GAL_SIG();	// Generate CAL signal with frequ ~10Hz
/*  Function name: loop                             */
/*  Parameters                                      */
/*    Input   :  No	                            */
/*    Output  :  No                                 */
/*    Action: Puts MCU into sleep mode.             */
 __asm__ __volatile__ ("sleep");
When you read the sticky thread labelled "How to use this forum - pleas read", which bits of "don't cross-post" and "use code tags" didn't you understand?
Suggestion:
Isolate what BT issues you may have.
  1. Start with a simple script to exercise BT to your PC and drop the data xfer rates to 9600. Send strings that would be representative of live data.
  2. Up the data rates to the goal of 57600
In theory, the BT is just a modem, so maybe there are setup or handshaking issues.
