Wires causing erratic signals
Hi guys,
I have used a microswitch SPDT to position my motor to home. And I have connected the output of this microswitch ( two wires) through a 2m, 12 core sensor actuator cable which leads into the micro controller (Mega256).
By doing so the signals that i receive in my serial monitor is erratic (ON and OFF). The sensor turns on high even when the circuit is not closed (Switch not pressed).
BUT when I directly connect the switch to the microcontroller, I don't face this issue. Is this an EMI or voltage drop concern? How do I get rid of this issue and route the connection through the 12 core cable without having an erratic jumping of signals?
I have not included the program on because I believe it to be a hardware issue. Do let me know if i would need to? Thanks.
Bijoy
Lets see a good picture of your soldered connections to the microswitch pins. IS this a new switch or a used one?
Are your switches wired to +5V, or GND? Are your inputs "INPUT", or "INPUT_PULLUP"?
If your switches are wired to ground, and your inputs are "INPUT", your input signals will be very very noise sensitive. If "INPUT_PULLUP", less so, but you may still need to add a small capacitor across the input. I think LarryD is about to ask this as well..
C
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
FYI
With 2 meters of cable that isn't twisted pair and also using a high power rated micro switch, I wouldn't rely on using the internal pullup of the MCU. There would be not near enough wetting current and high susceptibility to noise.
I would recommend using an external 4.7K pullup resistor and 1μF capacitor connected from the input to GND. This will provide adequate wetting current and about 5 ms of hardware debounce, which would be adequate for a micro switch.
A homing switch should be wired "normally closed", for safety/reliability.
Leo..
#include <Stepper.h>
int dirPin2 =3;        // Direction pin feeding motor
int pulPin2 = 2;        // Pulse pin feeding motor
int dirPin1 = 5;        // Direction pin bending motor
int pulPin1 = 4;        // Pulse pin bending motor
int limit1 = 25;        // Limit switch for bending motor        // Limit switch for secondary motor
int stswitch = 6;        // Start switch after homing
int LED_stswitch = 7;        // Relay for LED Start switch        // Relay for solenoid 2- solenoid for DCV for air nipper
int solrel3 = 12;        // relay for solenoid 3- solenoid for DCV for air nipper
int solrel4 = 8;        // relay for solenoid 3- solenoid for DCV for air nipper actuating cylinder
int val = limit1;
int oscsteps1 = 4500;
int oscsteps2 = 1200;
int wirefeed = 18600;
Stepper motor2 (200,3,2);
Stepper motor1 (200,5,4);
void homing()
  //***************************************** Moving bending motor to find home sensor****************************************************//
        digitalWrite(dirPin1, HIGH);                                                            // Setup bending motor to turn left
        do
           digitalWrite(pulPin1 , HIGH);
            delayMicroseconds(1000);
            digitalWrite(pulPin1 , LOW);
        while (digitalRead(val) == HIGH);                                                        // Motor turns left until touches limit 1
        Serial.println("triggered-moving to home position");
            motor1.step(-900);        // Positioning to start of forming
 //**************************************** Forming and cutting the wire***************************************************************//
void form_cut()
  int i=10;
            motor2.setSpeed(5000);
            motor2.step(5*(-wirefeed));
            motor2.step(5*(-wirefeed));   // Feeding wire first half
            delay (2000);
        do
            motor1.setSpeed(5000);                                                            // Winding steps in a loop
            motor1.step(-oscsteps1);
            delayMicroseconds(50);
            motor2.step(-oscsteps2);
            motor1.step(oscsteps1);
            i=i-1;
         while(i>0);
            delay (2000);
            motor2.setSpeed(5000);                                                             // Feeding wire second half
            delay(500);        // Delay to feed wire with secondary motor-second length
         digitalWrite(solrel4,HIGH);                                                           // Actuate the cylinder to move the nipper to position
         delay (2000);
         digitalWrite(solrel4,LOW);
         delay (2000);
         digitalWrite(solrel3,HIGH);                                                          // Actuate the air nipper acutator.
         delay (2000);
         digitalWrite(solrel3,LOW);
         delay (2000);
{        // Set up stepper motor pins
       pinMode(dirPin1, OUTPUT);
       pinMode(pulPin1, OUTPUT);
       pinMode(dirPin2, OUTPUT);
       pinMode(pulPin2, OUTPUT);
       pinMode(limit1 , INPUT_PULLUP);                                                         // Set up the limit switch
       pinMode(stswitch, INPUT_PULLUP);                                                        // Set up start switch
       pinMode(LED_stswitch, OUTPUT);
       pinMode(solrel3, OUTPUT);
       pinMode(solrel4, OUTPUT);
       homing();        // Call homing function
       digitalWrite(LED_stswitch,HIGH);                                                        // Once homing of both the wires are done, the "ready to start" LED comes on.
  while(digitalRead(stswitch) == HIGH);                                                        // Condition for after homing- start switch
       { digitalWrite(LED_stswitch,LOW);                                                       // Once switch is pressed light goes off.
           delay(100);        // Delay after homing + time to feed wire with secondary motor- first length
           for(int n=5;n>0;n--)
               form_cut();        // Call forming & cutting function
while(1);
Its a hand drawn circuit. would that help?
The black boxed section is what is in the field and the rest are in a control box.
its a new switch
As @Wawa said, wire the switch N.C.
Thanks @LarryD and @Wawa. Will do. But is that what is causing the erratic signals?
Almost certainly noise pickup. 4k7 pullups and some decoupling may well solve it.
Noise
Also, when this switch is at a distance.
In your situation, use the normally closed contact, then look for a HIGH as an indication the switch has operated.
Your latest code on a WOKWi simulation.
Notes:
  • Both slide switches default to having no bounce (clean signal transitions).
  • You'll need to work on replacing the while loops and delays with non-blocking code. I believe these multiple delays are actually what is causing your erratic operation (this is what the simulator shows).
  • Check simulator wiring to switches (may need to change default state).
