Is it possible to connect two oled displays via SPI to my Uno and send a single image to both displays, with each refreshing at an identical rate?
I have gotten a single oled display (SSD1306) to work using the U8g2 library, however i am not sure which pins can be shared in a dual display setup. There are no CS pin on my displays, only GND, VCC, SCL, SDA, D/C, and RST.
thanks!
