I have a Mega 2560 interfaced to a breadboard. The Mega is powered through the barrel jack, and the breadboard is powered using a 5V power supply connected to the power rails. I have connected the ground on the Mega and the breadboard together, so there is no float between the two.
The question is, should the +5 on each be connected? I can think of plausible sounding arguments either way.
If you provide barrel jack power the Mega's voltage regulator is active outputing 5V - two different 5V supplies will fight each other, possibly even oscillating and burning parts up.
You might be able to do away with the barrel jack supply and power the Mega from the 5V on the breadboard.
Thanks, I thought that might be the case. The voltage on the breadboard is dropping more than I would like, so I was hoping that load-sharing would be a thing.
