Hey, being a beginner I would need help to know how to wire all these components with a breadboard
Arduino UNO
TMC2209 motor driver
Joy-it NEMA-FLAT 01 stepper motor
ENCODER STEC11B01( to change motor speed)
Toggle Switch, 6A 125Vac 6 Pin Dpdt On-On (to change the direction of the motor)
Jack input (to receive CV info that will change motor speed)
I would also need help with coding, how to code from start to finish or where can I find these informations?
Like is there special change in the code concerning the jack input that will recieve CV info from a CV sequencer, the toggleswitch changing the direction of the motor? ect...
I already have this code for the motor driver
digitalWrite(Dbl, LOW);
while(!digitalRead(Sync))
digitalWrite(Mot, HIGH);
delayMicroseconds(Mspeed);
digitalWrite(Mot, LOW);
digitalWrite(Dbl, HIGH);
Also some extra questions:
Could I eventually wire the components directly to the arduino without a breadboard?
Do I need another power source than from arduino?
No. As a beginner to Arduino, you should start with Arduino basics. Your IDE has examples in IDE >> EXAMPLES >> BUILT-IN EXAMPLES >> (various levels and examples).
As a beginner to Forum.Arduino.CC, you should start with Forum basics. Your sketch needs to be formatted properly... 1. edit your post 2. select and cut your sketch out 3. format your sketch in your IDE (use paste, CTRL-T, select, cut) 4. in the forum click < CODE > 5. paste your sketch where you see type or paste your sketch here
You have been a "beginner" since 2021... take time to learn. You will benefit.
