Hello people,
I'm pretty new to Arduino and have a problem with my Arduino Uno:
The idea is to make a circuit that holds 6 buttons on it and that can talk to Processing so I can move a player around (as in RPG-style so also diagonal). I want it to have Up-Down-Left-Right and a combination of those would move the player diagonal.
Right now I have two buttons :
- Down
- Right
A combination of both will move the player.
For some reason, once I hook up a third button the controls start giving me combinations of all controls (I should only get one) and I have no idea what I'm doing wrong... (the upState variable is causing the problem of giving me combinations of all controls ~ which is the second button on my board)
My question now is: How do I make it so that Processing will understand that all the buttons on the board are unique and thus will not collide with other inputs?
Arduino code:
const int led = 13;
const int right = 2;
const int down = 3;
const int up = 5;
void setup(){
pinMode(led, OUTPUT);
pinMode(right, INPUT);
pinMode(down, INPUT);
pinMode(up, INPUT);
void loop(){
if(Serial.available() > 0) {
char ledState = Serial.read();
if (ledState == '1') {
digitalWrite(led, ledState);
if (ledState == '0') {
digitalWrite(led, LOW);
int rightState = digitalRead(right) ;
int downState = digitalRead(down);
int upState = digitalRead(up);
if (rightState > 0 || downState > 0 || upState > 0){
if (upState == HIGH) {
Serial.println("up");
if (rightState == LOW) {
Serial.println("down");
if (downState == LOW) {
Serial.println("right");
if (rightState ==HIGH && downState ==HIGH ) {
Serial.println("combirightdown");
Serial.println("nothing");
Processing Code
import processing.serial.*;
Serial myPort;
String inString;
int lf = 10;
boolean contact = false;
size (500,500);
println("Available serial ports:");
for(int i = 0; i < Serial.list().length; i++){
println("[" + i + "]" + Serial.list()[i]);
if (Serial.list().length > 0){
String portName = Serial.list()[0];
myPort = new Serial(this, portName, 9600);
myPort.bufferUntil(lf);
void serialEvent (Serial p) {
inString = p.readString();
void draw(){
background(0,0,0);
if (inString != null) {
inString = trim(inString);
if (contact == false) {
if (inString != null && !inString.isEmpty() && inString != " " && inString != ""){
if (inString.equals("A")) {
myPort.write("nothing");
if (inString.equals("down")) {
rect(10,10,10,10);
if (inString.equals("right")) {
rect(20,10,10,10);
if (inString.equals("up")) {
rect(20,120,10,10);
if (inString.equals("combirightdown")) {
rect(30,50,10,10);
println(inString);
if (mousePressed && (mouseButton == LEFT)){
myPort.write('1');
if (mousePressed && (mouseButton == RIGHT)) {
myPort.write('0');
Could someone help me?
