wiring two Hall sensors to one arduino input
Greetings,
I was wondering if it is possible to wire two Hall sensors on a single Arduino digital or analog input.
Rationale: I have two Hall sensors A3144 (very close one to each other) on a pad, to detect the presence of a magnet;
the activation of at least one sensor is enough for me to state that the magnet is close to the pad.
I would like to use only one Arduino input. Is it possible to arrange the two sensors in an hardware configuration to produce a logic 'OR'?
In this link the configuration I would like to have (I did not tried it).
Thanks,
Valerio
Since the A3144 is an open collector switch you can do the "wired OR" with them. I set up my Uno with 2 A3144 switches and the following code to test. I get a LOW when either sensor is in the magnetic field (of the proper polarity) and a HIGH when the magnet is away. Circuit is wired like your fritzing diagram except I use digital pin 4 (A3144 is a switch, a digital function) and 10K pullup resistors.
const byte hallPinA = 4;
   static unsigned long timer = 0;
   unsigned long interval = 200;
   if (millis() - timer >= interval)
      timer = millis();
      Serial.println(digitalRead(hallPinA));
How to post images so we do not have to download them.
How to post an image.
Another page on posting images.
Really thanks, I can confirm it works perfectly. I managed to arrange 3 hall sensors, using a single Arduino digital input.
Courteously,
Valerio
Open collector outputs driving a pull-up resistor are technically wired-AND. The output is HIGH only if both devices are outputing HIGH.
However if you use them active-LOW, then its wired-OR, logically if not physically...
