wiring up a Arduino to relay?
Got a CRYDOM 25A SOLID STATE RELAY 240V AC 25A LOAD (3 - 32V INPUT) in the post, just wonder if anyone schismatic for hooking the arduino in the best way. :-*
Just wire the positive input terminal to an Arduino output pin, the negative input terminal to a Arduino ground pin. The two AC terminals go in series with the AC hot lead. A setting the output pin high will cause AC current to flow to the load, and setting it low will turn it off.
Lefty
thank you as always retrolefty :-*
