WiShield 2.0 / WiServer / Arduino Uno / IDE 1.0 - Error
I am having trouble getting the IDE 1.0 to compile the code listed below:
 * Socket App
 * A simple socket application example using the WiShield 1.0
#include <WiShield.h>
#define WIRELESS_MODE_INFRA	1
#define WIRELESS_MODE_ADHOC	2
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,0,25};	// IP address of WiShield
unsigned char gateway_ip[] = {192,168,0,1};	// router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0};	// subnet mask for the local network
const prog_char ssid[] PROGMEM = {"ROUTER ID"};		// max 32 bytes
unsigned char security_type = 3;	// 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"WPA PASS"};	// max 64 characters
// WEP 128-bit keys
// sample HEX keys
prog_uchar wep_keys[] PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d,	// Key 0
				  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,	// Key 1
				  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,	// Key 2
				  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00	// Key 3
// setup the wireless mode
// infrastructure - connect to AP
// adhoc - connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
char buffer[20];
        Car_Setup();
	WiFi.init();
	WiFi.run();
      if (buffer[0] == 'A') { // Control specific pin
        //PSOCK_SEND_STR(&s->p, "LED Command: ");
        if (buffer[1] >= 3 && buffer[1] <= 12) {
          //PSOCK_SEND_STR(&s->p, "Correct, LED");
          //PSOCK_SEND(&s->p, &s->inputbuffer[1], 1);
          //PSOCK_SEND(&s->p, "=", 1);
          if (buffer[2] == 0) {
            pinMode(buffer[1], OUTPUT); // define as output
            digitalWrite(buffer[1], LOW);
            //PSOCK_SEND_STR(&s->p, "OFF");
            digitalWrite(buffer[1], HIGH);
            //PSOCK_SEND_STR(&s->p, "ON");
          //PSOCK_SEND_STR(&s->p, "Wrong!");
      if (buffer[0] == 'D') { // Control specific pin
        Serial.print("Drive ");
        if (buffer[1] == 'F') {
          Serial.print("forward: ");
          if (buffer[2] > 127) {
            Car_Drive(127);
            Serial.println(127, DEC);
            Car_Drive(buffer[2]);
            Serial.println(buffer[2], DEC);
        } else if (buffer[1] == 'B') {
          Serial.println("backward: ");
            Car_Drive(-127);
            Serial.println(-127, DEC);
            Car_Drive(-1 * buffer[2]);
            Serial.println(-1 * buffer[2], DEC);
      if (buffer[0] == 'T') { // Control specific pin
        Serial.print("Turn ");
        if (buffer[1] == 'R') { // Right
          Serial.println("right");
          Car_Turn(1);
        } else if (buffer[1] == 'L') { // Left
          Serial.println("left");
          Car_Turn(-1);
        } else if (buffer[1] == 'N') { // None
          Serial.println("none");
          Car_Turn(0);
      memset(buffer, 0x00, sizeof(buffer)); // Empty buffer
void Car_Setup()
  pinMode(3, OUTPUT); // Turn Right Pin
  digitalWrite(3, LOW);
  pinMode(4, OUTPUT); // Turn Left Pin
  digitalWrite(4, LOW);
  analogWrite(5, 0); // Go Forward PWM
  analogWrite(6, 0); // Go Backward PWM
void Car_Drive(signed char Direction) // Forward/Backward speed
  if (Direction > 0) {
    analogWrite(5, 2 * Direction); // Go Forward PWM
  } else if (Direction < 0) {
    analogWrite(5, 0); // Go Backward PWM
    analogWrite(6, -2 * Direction);         // Go Forward PWM
void Car_Turn(signed char Direction) // Positive=Right, Negative=Left
    digitalWrite(3, HIGH);  // Turn Right Pin
    digitalWrite(4, LOW);  // Turn Left Pin
    digitalWrite(3, LOW);  // Turn Right Pin
    digitalWrite(4, HIGH);  // Turn Left Pin
The error I recieve is:
WiFi_Controlled_Car.pde:-1: error: conflicting declaration 'const prog_char ssid []'
C:\Users\Kizz MyAnthia\Desktop\arduino-1.0\libraries\WiShield/config.h:44: error: 'ssid' has a previous declaration as 'char ssid []'
WiServer sample errors out:
WiServer:8: error: conflicting declaration 'const prog_char ssid []'
WiServer.cpp: In function 'int sendPage(char*)':
WiServer:42: error: no matching function for call to 'Server::print_P(char*, int&)'
C:\Users\Kizz MyAnthia\Desktop\arduino-1.0\libraries\WiShield/WiServer.h:203: note: candidates are: void Server::print_P(const char*)
WiServer.cpp: In function 'void setup()':
WiServer:81: error: invalid conversion from 'int (*)(char*)' to 'boolean (*)(char*)'
WiServer:81: error: initializing argument 1 of 'void Server::init(boolean (*)(char*))'
The specific parameter that is of issue is ssid[]. This variable is set in config.h and within the code above causing the multiple instance error. If I change the variable name in config.h then other pieces of the application that also use the function error because it can not be found. If I change the variable in my code the WiShield 2.0 does not connect.
Here is further information:
I know the WiShield & Arduino Uno (using IDE 1.0) works, the SimpleServer example works and provides the "Hello World!" text.
So I know the hardware, connection, and WiShield server function is working properly.
The specific part of the code that is the issue is:
If I change the "const prog_char" portion of the code to only "char" the code compiles successfully in IDE 1.0, but the WiShield does not connect to the WAP.
Any help is MUCH appreciated
Never used this library. Reading through the sources at github and your supplied pde it looks like the library you have is an older version and does not match the example code. Try to download the newest version of the library and retry.
I couldn't even get that far after trying for about an hour, and gave up. Is there not a more recent library?
I will verify the information, but I have tried this with the files from the Wiki. I will verify and attempt to compile with fresh copies of everything, if it has not changed I will update the post.
Latest version from github is v1.3.0. I modified only some includes to "arduino.h" and the return type of Server::write(uint8_t b) in WiServer.h/cpp to reflect recent changes in IDE.
You have to modify the defines in apps-conf.h and uip-conf.h to match your goal. The flash example is not working - I'm quite new to Arduino and do not know where dataflash.h comes from. The other examples are compilable with corresponding changes in apps-conf.h. The UDPApp example needs UDP support activated in uip-conf.h
 * UDP support on or off
 * \hideinitializer
#define UIP_CONF_UDP             1
Hope that helps somehow. I have no WiFi components for Arduino to test functionality.
asynclabs-WiShield-v1.3.0-mod4IDE1.0.zip (137 KB)
dataflash.h is part of the dataflash library that can be downloaded from WiShield 2.0 Wiki.
I did resolve all the issues by replacing all of the files to the most updated available ones and clean of any changes.
