WiShield And Arduino Demovian
I am currently trying to connect my WiShield v1.0 to my wifi router. I am able to get it connected and display the information when I go to its IP address, I also have a LM335 Temperature monitor that is able to print all of the temperatures in Serial but I just don't know how to get it to print it on the webpage. Here is the code, can someone please help me get this to print on the webpage.
 * Web Server
 * A simple web server example using the WiShield 1.0
#include <WiShield.h>
#include <WiServer.h>
#include <SPI.h>
#define WIRELESS_MODE_INFRA	1
#define WIRELESS_MODE_ADHOC	2
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,1,102};	// IP address of WiShield
//byte mac[] = { E0:91:F5:09:84:5A };
unsigned char gateway_ip[] = {192,168,1,1};	// router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0};	// subnet mask for the local network
const prog_char ssid[] PROGMEM = {"SmartHome"};		// max 32 bytes
unsigned char security_type = 0;	// 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"DeadBeef"};	// max 64 characters
// WEP 128-bit keys
// sample HEX keys
prog_uchar wep_keys[] PROGMEM = {	0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d,	// Key 0
									0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,	0x00,	// Key 1
									0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,	0x00,	// Key 2
									0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,	0x00	// Key 3
// setup the wireless mode
// infrastructure - connect to AP
// adhoc - connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
float temp_in_celsius = 0;
float temp_in_kelvin=0;
float temp_in_fahrenheit=0;
// This is the webpage that is served up by the webserver
const prog_char webpage[] PROGMEM = {"HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<center><h1>Hello World!! I am WiShield</h1><form method=\"get\" action=\"0\">Toggle LED:<input type=\"submit\" name=\"0\" value=\"LED1\"></input></form></center>"};
// This is our page serving function that generates web pages7
  WiFi.init();
void loop(){
  WiFi.run();
    //Reads the input and converts it to Kelvin degrees
  temp_in_kelvin = analogRead(0) * 0.004882812 * 100;
  //Converts Kelvin to Celsius minus 2.5 degrees error
  temp_in_celsius = temp_in_kelvin - 2.5 - 273.15;
  temp_in_fahrenheit = ((temp_in_kelvin - 2.5) * 9 / 5) - 459.67;
  //Print the temperature in Celsius to the serial port
  Serial.print("Celsius: ");
  Serial.println(temp_in_celsius);
  //Print the temperature in Fahrenheit to the serial port
  Serial.print("Fahrenheit: ");
  Serial.println(temp_in_fahrenheit);
  Serial.print("Kelvin:  ");
  Serial.println(temp_in_kelvin);
Hello ,
The code for the url is not in the loop on the WiShield, i will post mine ( i am using the DHT11 sensor for the temp. and hum.) if you want convert the part for you're sensor.
Here you are:
#include "DHT.h"
#define DHTPIN 5 // what pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
unsigned char local_ip[] = {192,168,2,22};	// IP address of WiShield
unsigned char gateway_ip[] = {192,168,2,1};	// router or gateway IP address
const prog_char ssid[] PROGMEM = {"NetFasteR_rXfAD4"};		// max 32 bytes
unsigned char security_type = 3;	// 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
const prog_char security_passphrase[] PROGMEM = {"password"};	// max 64 characters
// WEP 128-bit keys
// sample HEX keys
// End of wireless configuration parameters ----------------------------------------
boolean sendMyPage(char* URL) {
        // Reading temperature or humidity takes about 250 milliseconds!
        // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
        float h = dht.readHumidity();
        float t = dht.readTemperature();
        // check if returns are valid, if they are NaN (not a number) then something went wrong!
        if (isnan(t) || isnan(h)) {
        	WiServer.print("<html>");  //Here is the code for the html page
         //Serial.println("Failed to read from DHT");  // Here is the code for Serial port, monitor only...
         	WiServer.print("Failed to read from DHT");
        	WiServer.println("        </html>");
        /* Serial.print("Humidity: ");
         Serial.print(h);
         Serial.print(" %\t");
         Serial.print("Temperature: ");
         Serial.print(t);
         Serial.println(" *C");*/
        	WiServer.print("<center><H2>Site are Home:  Sensor ID: 1</H2>
        WiServer.print("Humidity: ");
        WiServer.print(h);
        WiServer.print(" %\t");
        WiServer.print("Temperature: ");
        WiServer.print(t);
        WiServer.println(" *C");
        WiServer.println("        ");
        WiServer.print("</center></html>");
        // URL was recognized
        return true;
    // URL not found
    return false;
  // Initialize WiServer and have it use the sendMyPage function to serve pages
  WiServer.init(sendMyPage);
  // Enable Serial output and ask WiServer to generate log messages (optional)
  Serial.begin(57600);
  WiServer.enableVerboseMode(true);
  dht.begin();
void loop(){
  // Run WiServer
  WiServer.server_task();
  delay(10);
Don't forgot also to change the ip in case if it is different, and the WEP key (or what you have) to you
Here is mine
