Hi guys,
i have a little problem i'm not even able to understand...
I wrote this simple sketch to make my Arduino write on a web page a temperature from a ds18b20; it works fine but it takes about 23 seconds to open the page.... too long...
I've also tried to modify some part of the code and i found that is the "sensors.requestTemperatures();" in void loop that makes the web rendering so slow. Infact, if i remove it and assign a static value to the temperature the web page appears instantly.
Can somebody help me?
this is the code:
#include <WiServer.h>
#define WIRELESS_MODE_INFRA 1
#define WIRELESS_MODE_ADHOC 2
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 8
#define TEMPERATURE_PRECISION 12
DeviceAddress sonda1={0X28, 0XAC, 0XF6, 0XA7, 0X03, 0X00, 0X00, 0XCE};
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
//float tempC = sensors.getTempC(sonda1);
// Wireless configuration parameters —————————————-
unsigned char local_ip[] = {192,168,1,120}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
const prog_char ssid[] PROGMEM = {"Cisco Home 2,4 gHz"}; // max 32 bytes
unsigned char security_type = 3; // 0 – open; 1 – WEP; 2 – WPA; 3 – WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"xxx"}; // max 64 characters
// WEP 128-bit keys
// sample HEX keys
prog_uchar wep_keys[] PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, // Key 0
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 1
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 2
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 // Key 3
// setup the wireless mode
// infrastructure – connect to AP
// adhoc – connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
// End of wireless configuration parameters —————————————-
// This is our page serving function that generates web pages
boolean sendMyPage(char* URL) {
// if (strcmp(URL, "/") == 0) {
// Use WiServer’s print and println functions to write out the page content
WiServer.print("<html>");
WiServer.print("Temperatura: ");
//WiServer.print(tempC);
WiServer.print(sensors.getTempC(sonda1));
WiServer.print("</html>");
// URL was recognized
return true;
// URL not found
return false;
// Initialize WiServer and have it use the sendMyPage function to serve pages
WiServer.init(sendMyPage);
// Enable Serial output and ask WiServer to generate log messages (optional)
//Serial.begin(57600);
//WiServer.enableVerboseMode(true);
//Serial.begin(9600);
sensors.begin();
sensors.setResolution(sonda1, TEMPERATURE_PRECISION);
void loop(){
WiServer.server_task();
// delay(10);
