I have a motorcycle with double headlights, and double daylight running light (DRL)
The DRL is white as standard
I want to remove the standard light, and put 1 led strip of 20 leds in each DRL
when the ignition turns on, I want a nightrider sequence in white or rainbow color one or two times, then white come on.
if I put the turn signal on, I want the 20 led strip, turn amber in a sequential mode until I turn it off, and then it goes back to white DRL
witch arduino would I use ?
Arduino uno ?
Arduino nano
Arduino micro
other ?
and how should the code look like ?
all help is grateful
