witch library for this screen 2.4 please ?
Hello
I have broken glass on my screen and I buy this one
Witch driver can I use with this ? Thank you.
The shield is fully assembled, tested and ready to go. No wiring, no soldering! Simply plug it in and load up our library - you’ll have it running in under 10 minutes! Works best with any classic (UNO/Duemilanove/Diecimila). This shield does NOT work with the Mega but its going to be half the speed of the Uno-type boards because of the way the Mega rearranges all the pins (there is no way to get around this!) This shield is not Leonardo-compatible
Description:
Spice up your project with a beautiful large touchscreen display shield with built in microSD card connection. This TFT display is big (2.4" diagonal) bright (4 white-LED backlight) and colorful (18-bit 262,000 different shades)! 240x320 pixels with individual pixel control. It has way more resolution than a black and white 128x64 display. As a bonus, this display has a resistive touchscreen attached to it already, so you can detect finger presses anywhere on the screen.
Technical Details:
2.4" diagonal LCD TFT display
240x320 resolution, 18-bit (262,000) color
spfd5408 controller with built in video RAM buffer
8 bit digital interface, plus 4 control lines
Uses digital pins 5-13 and analog 0-3. That means you can use digital pins 2, 3 and analog 4 and 5. Pin 12 is available if not using the microSD
Works with any '328 or Mega (Leonardo not supported yet)
5V compatible! Use with 3.3V or 5V logic
Onboard 3.3V 300mA LDO regulator
4 white LED backlight. On by default but you can connect the transistor to a digital pin for backlight control
4-wire resistive touch screen
[https://fr.aliexpress.com/item/Free-shipping-5pcs-lot-LCD-module-TFT-2-4-inch-TFT-LCD-screen-for-Arduino-UNO/1874979237.html](http://website I buy it)
Go on. You have made 100 posts. And you have already used the MCUFRIEND_kbv library.
Update the library with the Library Manager.
Run the diagnose_TFT sketch.
David.
Hello
This is a common screen so. I question the seller's description. There is no reason it should not work on a Mega2560. I also question the seller's statement that it would not work with an Arduino Leonardo. The pin outs of the boards are identical concerning any shield.
I am baffled as to what the issue is. There are numerous examples in the Arduino IDE to use and test TFT displays.
david_prentice:
David.
It is not writted "mcfriend" and can I be not sure about what is right to do ?
padouet:
You got a display that is made for Arduino UNO. From the labels you can deduce it uses 8bit parallel.
You know the library MCUFRIEND_kbv, it is THE library most used for these displays. And it is excellent in identifying any display connected that supports read operations.
So why not try with this library first, just because "mcufriend" is not written on it? Most of these are clones anyway.
