Witch sketch is in my unit now
Is it possible to check witch program/sketch I have in a specific unit before I upload another?
Jörgen
It's always the last one you uploaded.
I usually put Serial.println("nameOfSketch"); in setup()
Without something like that there is no easy way to tell.
...R
If you are likely to need to know which sketch is currently loaded then think about doing a Serial.print() in setup() that tells you or, more complicated, blink a code using the LED on pin 13
If you are using a display, use setup to briefly display program info.
Tom.... :slight_smile:
UKHeliBob:
That is a good idea!
Thank You!
Jörgen
