with error expected unqualified-id before'if'
I need help with my code it has gave me this error:'error expected unqualified-id before 'if'' dont know whats wrong. Plz help.
Thank you!
int ledpin1 = 3;
int ledpin2 = 4;
int relaypin = 2;
long previousMillis_1 = 0;
long ledpin_interval = 1000;
long previousMillis_2 = 300;
long relay_interval = 10000;
int count = 0;
int tempc = 0;
int tempmv = 0;
int tempF = 0;
//input
int lm19pin = 0;
    pinMode(ledpin1, OUTPUT);             // initialize the digital pin as an output
    pinMode(ledpin2, OUTPUT);
    pinMode(relaypin, OUTPUT);            // initialize the digital pin as an output
    pinMode(lm19pin, INPUT);                // initialize the digital pin as an intput
    Serial.begin(2400);                    // set up serial output
if (millis() - previousMillis_1 > ledpin_interval) {
          previousMillis_1 = millis();
         digitalWrite(ledpin1,HIGH);          //set the led high
         digitalWrite(ledpin1, HIGH);          //set the led high
         digitalWrite(ledpin2, LOW);           //set the led off
else{
      digitalWrite(ledpin2, HIGH);
 if (millis() - previousMillis_2 > relaypin_interval) {
      previousMillis_2 = millis();
      if (digitalWrite(relaypin, LOW)){
        count++;
      else{
      digitalWrite(ledpin, LOW);
   // lm19_val=analogRead(lm19Pin);          //read value of center leg of LM19 on source
   // tempmV = lm19_val;                      //output voltage of LM19, 10mV = 1 Degree Celcius
   //tempF=(5*tempmV*100/1024);             //mV converted to farenheit
    //tempc=((tempf-32)*5/9);                 //farenheit to celsius
  Serial.print("$GPUMD1,");
 // Serial.print(count,tempc);
:o
else{
[glow]  }  // <--- Remove this[/glow]
yeah I found out about that. Thanks for the help...
