I´m trying to sync an Arduino FIO with XBee with the coordinator of my network. The code works as follows:
- A coordinator sends to arduino FIO its UNIX time.
- Arduino FIO receives the UNIX time of the server, process it and set the system time with setTime();
The time is set correctly but the system allways reports the same time (calling to hour(), minute() and second() ).
example:
11:17:58 2 12 2010
11:17:58 2 12 2010
11:17:58 2 12 2010
11:17:58 2 12 2010
11:17:58 2 12 2010
11:17:58 2 12 2010
It is possible that newSoftwareSerial disables the interrupts that works with the system time???
- This file is part of XBee-Arduino (Andrew Rapp)
- XBee-Arduino is free software: you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation, either version 3 of the License, or
- (at your option) any later version.
- XBee-Arduino is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with XBee-Arduino. If not, see http://www.gnu.org/licenses/.
*/#include <XBee.h>
#include <NewSoftSerial.h>
#include <Time.h>#define TIME_MSG_LEN 10 // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
#define TIME_REQUEST 7 // ASCII bell character requests a time sync messageXBee xbee = XBee();
XBeeResponse response = XBeeResponse();
// create reusable response objects for responses we expect to handle
ZBRxResponse rx = ZBRxResponse();
ModemStatusResponse msr = ModemStatusResponse();// Define NewSoftSerial TX/RX pins
// Connect Arduino pin 9 to TX of usb-serial device
uint8_t ssRX = 9;
// Connect Arduino pin 10 to RX of usb-serial device
uint8_t ssTX = 10;
// Remember to connect all devices to a common Ground: XBee, Arduino and USB-Serial device
NewSoftSerial nss(ssRX, ssTX);char message[10];
int sync=0;void setup() {
//setSyncProvider( requestSync); //set function to call when sync required// start serial
xbee.begin(57600);
nss.begin(57600);nss.println("starting up yo!");
nss.println("Waiting for sync message");
}// continuously reads packets, looking for ZB Receive or Modem Status
void loop() {if(sync!=1)
requestTime();
else{
processSyncMessage();if(timeStatus()!= timeNotSet)
digitalWrite(13,timeStatus() == timeSet); // on if synced, off if needs refresh
digitalClockDisplay();
}//TIME FUNCTIONS
void digitalClockDisplay(){
// digital clock display of the time
nss.print(hour());
printDigits(minute());
printDigits(second());
nss.print(" ");
nss.print(day());
nss.print(" ");
nss.print(month());
nss.print(" ");
nss.print(year());
nss.println();
}void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
nss.print(":");
if(digits < 10)
nss.print('0');
nss.print(digits);
}void processSyncMessage() {
// if time sync available from serial port, update time and return true
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN ; i++){
int c = (int)message*; *
_ //nss.print(message*, DEC); [/color]_
_ //nss.println(c); _
_ if( c >= 0 && c <= 9){ _
_ pctime = (10 * pctime) + (c - 0) ; // convert digits to a number _
_ }_
_ } _
_ now();*_* setTime(pctime); // Sync Arduino clock to the time received on the serial port*
time_t requestSync()
* nss.print(TIME_REQUEST,BYTE);
_ return 0; // the time will be sent later in response to serial mesg*_
//FUNCTIONS HEX TO ASCII
char hexNibbleToChar(char nibble)
* if (nibble >= '0' && nibble <= '9')*
* return nibble - '0';*
* else if (nibble >= 'a' && nibble <= 'f')*
* return 10 + nibble - 'a';*
* else*
* return 10 + nibble - 'A';*
void requestTime()
* xbee.readPacket();*
* if (xbee.getResponse().isAvailable()) {*
* // got something*
* nss.println("got something");*
* nss.println(xbee.getResponse().getApiId(), HEX); *
* if (xbee.getResponse().getApiId() == ZB_EXPLICIT_RX_RESPONSE ){
//if (ZB_RX_RESPONSE == ZB_RX_RESPONSE) {
_ // got a zb rx packet*_
* // now fill our zb rx class*
* xbee.getResponse().getZBRxResponse(rx);*
* nss.println("Got an rx packet!");*
* if (rx.getOption() == ZB_PACKET_ACKNOWLEDGED) {
_ // the sender got an ACK*_
* nss.println("packet acknowledged");*
* else {*
* nss.println("packet not acknowledged");*
* nss.print("checksum is ");*
* nss.println(rx.getChecksum(), HEX);*
* nss.print("packet length is ");*
* nss.println(rx.getPacketLength(), DEC);*
* for (int i = 6; i < rx.getDataLength(); i++) {*
* nss.print("frame data [");*
* nss.print(i, DEC);*
* nss.print("] is ");*
_ char stringOne = char(rx.getData());
* stringOne = hexNibbleToChar(stringOne);
message[i-6] = stringOne;
nss.println(rx.getData(), DEC);
nss.print(message[i-6], DEC);
//Check if we have a message with the time*
* sync=1;
else if (xbee.getResponse().isError()) {
nss.print("oh no!!! error code:");
nss.println(xbee.getResponse().getErrorCode());
[/quote]*_
