With the arduino nano how can I read an input at the same time that I read the text messages of the sim800L
Hi everyone!
I am working with an arduino nano and the Sim800L, but I am having a problem, when I consult the incoming text messages of the sim800L, which are checked using a loop, if while this happens I try to read an input by means of a button, this signal is loses, since the messages of the sim800L were being read while the input was pressed, so i would like to know how can i read the two at same time
I look forward to a prompt response
Thanks
Don't use for-loops or while-loops. Have a look at Robin's Serial Input Basics - updated to get ideas for non-blocking reads of the serial interface.
Further read Demonstration code for several things at the same time ; there are more articles on the web like this one.
Replied within 10 minutes, hope that that is prompt enough :joy:
Not at EXACTLY the same time. Mainly you want to avoid any code that blocks other processing. The following tutorials will help you understand:
BlinkWithoutDelay
Arduino Multiple Things
Several Things at a Time
thank you very much for your quick response, i will read this articles!
