With this Bosch DS160 PIR Sensor work with an Ardunio?
I am researching PIR sensors for an upcoming project and was wondering if anyone had any insight if this sensor will work with an Ardunio?
http://absupply.net/images/ds160.pdf
Thanks!
Yes, they will work. But the sensor needs 12V to 30V as power supply. The output is probably a relay output, so you can use the Arduino digital input for that.
It seems a bit odd to me to use that sensor. The sensor contains the PIR sensor and a microcontroller. The Arduino would be a second microcontroller, so why not use a good quality PIR sensor with the Arduino.
