with two sensor
I am trying to use two pir sensors. and here i want to light on the led when 1 is high and switch it off when 2 is high.. please help me with this
const int p1Pin = 1;
const int p2Pin = 2;
const int ledPin = 13;
int p1State =0;
int p2State =0;
void setup () {
pinMode (ledPin, OUTPUT);
pinMode (p1Pin, INPUT);
pinMode (p2Pin, INPUT);
void loop () {
p1State = digitalRead(p1Pin);
p2State = digitalRead(p2Pin);
if (p1State == HIGH) {
digitalWrite(ledPin, HIGH);
if (p2State == HIGH) {
digitalWrite(ledPin, LOW);
How far apart are the sensors? How does what this code does differ from what you want to have happen?
Digital pins 0 and 1 are the serial port. Unless you absolutely must use pin 1, you'd be well advised not to.
Add a call to Serial.begin() in setup(), after you change the PIR pin. Add calls to Serial.print() and/or Serial.println() in loop(), to see what is happening in your code/with your hardware.
