So I have this code from the witmotion sdk. I have the Witmotion WT901C232 Sensor.
#include <REG.h>
#include <wit_c_sdk.h>
Test on UNO R3. use WT901CTTL sensor
WT901232 UNO R3
VCC <---> 5V/3.3V
TX <---> 1(TX1)
RX <---> O(RX1)
GND <---> GND
#define ACC_UPDATE 0x01
#define GYRO_UPDATE 0x02
#define ANGLE_UPDATE 0x04
#define MAG_UPDATE 0x08
#define READ_UPDATE 0x80
static volatile char s_cDataUpdate = 0, s_cCmd = 0xff;
static void CmdProcess(void);
static void AutoScanSensor(void);
static void SensorUartSend(uint8_t *p_data, uint32_t uiSize);
static void SensorDataUpdata(uint32_t uiReg, uint32_t uiRegNum);
static void Delayms(uint16_t ucMs);
const uint32_t c_uiBaud[8] = {0,4800, 9600, 19200, 38400, 57600, 115200, 230400};
WitInit(WIT_PROTOCOL_NORMAL, 0x50);
WitSerialWriteRegister(SensorUartSend);
WitRegisterCallBack(SensorDataUpdata);
WitDelayMsRegister(Delayms);
Serial.print("\r\n********************** wit-motion normal example ************************\r\n");
AutoScanSensor();
int i;
float fAcc[3], fGyro[3], fAngle[3];
while (Serial1.available())
WitSerialDataIn(Serial1.read());
while (Serial.available())
CopeCmdData(Serial.read());
CmdProcess();
if(s_cDataUpdate)
for(i = 0; i < 3; i++)
fAcc[i] = sReg[AX+i] / 32768.0f * 16.0f;
fGyro[i] = sReg[GX+i] / 32768.0f * 2000.0f;
fAngle[i] = sReg[Roll+i] / 32768.0f * 180.0f;
if(s_cDataUpdate & ACC_UPDATE)
Serial.print("acc:");
Serial.print(fAcc[0], 3);
Serial.print(" ");
Serial.print(fAcc[1], 3);
Serial.print(" ");
Serial.print(fAcc[2], 3);
Serial.print("\r\n");
s_cDataUpdate &= ~ACC_UPDATE;
if(s_cDataUpdate & GYRO_UPDATE)
Serial.print("gyro:");
Serial.print(fGyro[0], 1);
Serial.print(" ");
Serial.print(fGyro[1], 1);
Serial.print(" ");
Serial.print(fGyro[2], 1);
s_cDataUpdate &= ~GYRO_UPDATE;
if(s_cDataUpdate & ANGLE_UPDATE)
Serial.print("angle:");
Serial.print(fAngle[0], 3);
Serial.print(" ");
Serial.print(fAngle[1], 3);
Serial.print(" ");
Serial.print(fAngle[2], 3);
s_cDataUpdate &= ~ANGLE_UPDATE;
if(s_cDataUpdate & MAG_UPDATE)
Serial.print("mag:");
Serial.print(sReg[HX]);
Serial.print(" ");
Serial.print(sReg[HY]);
Serial.print(" ");
Serial.print(sReg[HZ]);
s_cDataUpdate &= ~MAG_UPDATE;
s_cDataUpdate = 0;
void CopeCmdData(unsigned char ucData)
static unsigned char s_ucData[50], s_ucRxCnt = 0;
s_ucData[s_ucRxCnt++] = ucData;
if(s_ucRxCnt<3)return; //Less than three data returned
if(s_ucRxCnt >= 50) s_ucRxCnt = 0;
if(s_ucRxCnt >= 3)
if((s_ucData[1] == '\r') && (s_ucData[2] == '\n'))
s_cCmd = s_ucData[0];
memset(s_ucData,0,50);
s_ucRxCnt = 0;
s_ucData[0] = s_ucData[1];
s_ucData[1] = s_ucData[2];
s_ucRxCnt = 2;
static void ShowHelp(void)
Serial.print("\r\n************************ WIT_SDK_DEMO ************************");
Serial.print("\r\n************************ HELP ************************\r\n");
Serial.print("UART SEND:a\\r\\n Acceleration calibration.\r\n");
Serial.print("UART SEND:m\\r\\n Magnetic field calibration,After calibration send: e\\r\\n to indicate the end\r\n");
Serial.print("UART SEND:U\\r\\n Bandwidth increase.\r\n");
Serial.print("UART SEND:u\\r\\n Bandwidth reduction.\r\n");
Serial.print("UART SEND:B\\r\\n Baud rate increased to 115200.\r\n");
Serial.print("UART SEND:b\\r\\n Baud rate reduction to 9600.\r\n");
Serial.print("UART SEND:R\\r\\n The return rate increases to 10Hz.\r\n");
Serial.print("UART SEND:r\\r\\n The return rate reduction to 1Hz.\r\n");
Serial.print("UART SEND:C\\r\\n Basic return content: acceleration, angular velocity, angle, magnetic field.\r\n");
Serial.print("UART SEND:c\\r\\n Return content: acceleration.\r\n");
Serial.print("UART SEND:h\\r\\n help.\r\n");
Serial.print("******************************************************************************\r\n");
switch(s_cCmd)
case 'a': if(WitStartAccCali() != WIT_HAL_OK) Serial.print("\r\nSet AccCali Error\r\n");
case 'm': if(WitStartMagCali() != WIT_HAL_OK) Serial.print("\r\nSet MagCali Error\r\n");
case 'e': if(WitStopMagCali() != WIT_HAL_OK) Serial.print("\r\nSet MagCali Error\r\n");
case 'u': if(WitSetBandwidth(BANDWIDTH_5HZ) != WIT_HAL_OK) Serial.print("\r\nSet Bandwidth Error\r\n");
case 'U': if(WitSetBandwidth(BANDWIDTH_256HZ) != WIT_HAL_OK) Serial.print("\r\nSet Bandwidth Error\r\n");
case 'B': if(WitSetUartBaud(WIT_BAUD_115200) != WIT_HAL_OK) Serial.print("\r\nSet Baud Error\r\n");
Serial1.begin(c_uiBaud[WIT_BAUD_115200]);
Serial.print(" 115200 Baud rate modified successfully\r\n");
case 'b': if(WitSetUartBaud(WIT_BAUD_9600) != WIT_HAL_OK) Serial.print("\r\nSet Baud Error\r\n");
Serial1.begin(c_uiBaud[WIT_BAUD_9600]);
Serial.print(" 9600 Baud rate modified successfully\r\n");
case 'r': if(WitSetOutputRate(RRATE_1HZ) != WIT_HAL_OK) Serial.print("\r\nSet Baud Error\r\n");
else Serial.print("\r\nSet Baud Success\r\n");
case 'R': if(WitSetOutputRate(RRATE_10HZ) != WIT_HAL_OK) Serial.print("\r\nSet Baud Error\r\n");
case 'C': if(WitSetContent(RSW_ACC|RSW_GYRO|RSW_ANGLE|RSW_MAG) != WIT_HAL_OK) Serial.print("\r\nSet RSW Error\r\n");
case 'c': if(WitSetContent(RSW_ACC) != WIT_HAL_OK) Serial.print("\r\nSet RSW Error\r\n");
case 'h': ShowHelp();
default :break;
s_cCmd = 0xff;
Serial1.write(p_data, uiSize);
Serial1.flush();
delay(ucMs);
int i;
for(i = 0; i < uiRegNum; i++)
switch(uiReg)
case AZ:
s_cDataUpdate |= ACC_UPDATE;
case GZ:
s_cDataUpdate |= GYRO_UPDATE;
case HZ:
s_cDataUpdate |= MAG_UPDATE;
case Yaw:
s_cDataUpdate |= ANGLE_UPDATE;
default:
s_cDataUpdate |= READ_UPDATE;
uiReg++;
int i, iRetry;
for(i = 0; i < sizeof(c_uiBaud)/sizeof(c_uiBaud[0]); i++)
Serial1.begin(c_uiBaud[i]);
Serial1.flush();
iRetry = 2;
s_cDataUpdate = 0;
do
WitReadReg(AX, 3);
delay(200);
if(s_cDataUpdate != 0)
Serial.print(c_uiBaud[i]);
Serial.print(" baud find sensor\r\n\r\n");
ShowHelp();
return ;
iRetry--;
}while(iRetry);
Serial.print("can not find sensor\r\n");
Serial.print("please check your connection\r\n");
I simplified it like this due to memory issues because all I want is just readings.
#include <REG.h>
static volatile char s_cDataUpdate = 0;
const uint32_t c_uiBaud[8] = {0, 4800, 9600, 19200, 38400, 57600, 115200, 230400};
while (Serial.available()) {
WitSerialDataIn(Serial.read());
if (s_cDataUpdate) {
for (int i = 0; i < 3; i++) {
fAcc[i] = sReg[AX + i] / 32768.0f * 16.0f;
fGyro[i] = sReg[GX + i] / 32768.0f * 2000.0f;
fAngle[i] = sReg[Roll + i] / 32768.0f * 180.0f;
if (s_cDataUpdate & ACC_UPDATE) {
Serial.print(fAcc[0], 3); Serial.print(" ");
Serial.print(fAcc[1], 3); Serial.print(" ");
Serial.println(fAcc[2], 3);
if (s_cDataUpdate & GYRO_UPDATE) {
Serial.print(fGyro[0], 1); Serial.print(" ");
Serial.print(fGyro[1], 1); Serial.print(" ");
Serial.println(fGyro[2], 1);
if (s_cDataUpdate & ANGLE_UPDATE) {
Serial.print(fAngle[0], 3); Serial.print(" ");
Serial.print(fAngle[1], 3); Serial.print(" ");
Serial.println(fAngle[2], 3);
void SensorUartSend(uint8_t *p_data, uint32_t uiSize) {
Serial.write(p_data, uiSize);
Serial.flush();
void Delayms(uint16_t ucMs) {
delay(ucMs);
void SensorDataUpdata(uint32_t uiReg, uint32_t uiRegNum) {
for (uint32_t i = 0; i < uiRegNum; i++) {
switch (uiReg) {
case AZ:
case GZ:
case Yaw:
default:
uiReg++;
Both codes , I get encrypted characters and I changed baud rates aswell and I cannot get any readings at all.
