WizNet 550IO compile issue
Need some guidance from someone experienced with this module. Fresh install of Arduino 1.0.6 Installed wiznet library files into my sketch folder - https://github.com/Wiznet/WIZ_Ethernet_Library Uncommented the 5500 section
Get the following errors:
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences. Arduino: 1.0.6 (Windows 7), Board: "Arduino Duemilanove w/ ATmega328" C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp: In member function 'void W5500Class::init()': C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:29: error: no matching function for call to 'SPIClass::begin(int)' C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:45: note: candidates are: static void SPIClass::begin() C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:34: error: no matching function for call to 'SPIClass::setClockDivider(int, int)' C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:50: note: candidates are: static void SPIClass::setClockDivider(uint8_t) C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:35: error: no matching function for call to 'SPIClass::setDataMode(int, int)' C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:49: note: candidates are: static void SPIClass::setDataMode(uint8_t) C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp: In static member function 'static uint8_t W5500Class::write(uint16_t, uint8_t, uint8_t)': C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:116: error: 'SPI_CONTINUE' was not declared in this scope C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:119: error: no matching function for call to 'SPIClass::transfer(int, uint8_t&)' C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:55: note: candidates are: static byte SPIClass::transfer(byte) C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp: In static member function 'static uint16_t W5500Class::write(uint16_t, uint8_t, const uint8_t*, uint16_t)': C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:137: error: 'SPI_CONTINUE' was not declared in this scope C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:143: error: no matching function for call to 'SPIClass::transfer(int, const unsigned char&)' C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:55: note: candidates are: static byte SPIClass::transfer(byte) C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp: In static member function 'static uint8_t W5500Class::read(uint16_t, uint8_t)': C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:159: error: 'SPI_CONTINUE' was not declared in this scope C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:162: error: no matching function for call to 'SPIClass::transfer(int, int)' C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:55: note: candidates are: static byte SPIClass::transfer(byte) C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp: In static member function 'static uint16_t W5500Class::read(uint16_t, uint8_t, uint8_t*, uint16_t)': C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:180: error: 'SPI_CONTINUE' was not declared in this scope C:\Users\Steve\Documents\arduino_sketch_wiznet\libraries\Ethernet\utility\w5500.cpp:186: error: no matching function for call to 'SPIClass::transfer(int, int)' C:\Program Files (x86)\Arduino\libraries\SPI/SPI.h:55: note: candidates are: static byte SPIClass::transfer(byte)
I deleted the ethernet folder in my sketchbook library folder. redownloaded from github, copied back into my sketchbook libraries folder, verified that the 550 module was uncommented, restarted the ide, reloaded the example web server sketch, and now the WizNet 550 IO module is now working
Here is the complete wiring diagrams, sketch, and instructions - http://arduinotronics.blogspot.com/2015/02/wiznet-550-io-ethernet-module.html
