Die Library Adafruit_ILI9341 musst Du aus dem Entpackten GitHub Ordner in Deinen Library Ordner verschieben.
Du hast ja das
heruntergeladen oder?
Du hast ja das
Sorry dort ist nur die .ino .
Habe was durcheinander gebracht , nicht genau geschaut.
Du musst die Adafruit_ILI9341 extra installieren und danach die 1-Adafruit_ILI9341_Test.ino ausführen
// The following code is the Adafruit ILI9341 example code modified by Jonny Bergdahl
// for use on the ESP32-2432S028R board.
// Install the bb_spi_lcd Library from the library manager.
// https://github.com/bitbank2/bb_spi_lcd
This is our GFX example for the Adafruit ILI9341 Breakout and Shield
----> http://www.adafruit.com/products/1651
Check out the links above for our tutorials and wiring diagrams
These displays use SPI to communicate, 4 or 5 pins are required to
interface (RST is optional)
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
MIT license, all text above must be included in any redistribution
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#define TFT_BL 21
#define TFT_CS 15
#define TFT_DC 2
#define TFT_MISO 12
#define TFT_MOSI 13
#define TFT_SCLK 14
#define TFT_RST -1
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST, TFT_MISO);
Serial.println("ILI9341 Test!");
// Note: The Adafruit librarys is not setting the backlight on, so we need to do that in code
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
tft.begin();
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(ILI9341_RDMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDPIXFMT);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDIMGFMT);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDSELFDIAG);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
Serial.println(F("Benchmark Time (microseconds)"));
delay(10);
Serial.print(F("Screen fill "));
Serial.println(testFillScreen());
Serial.print(F("Text "));
Serial.println(testText());
delay(3000);
Serial.print(F("Lines "));
Serial.println(testLines(ILI9341_CYAN));
Serial.print(F("Horiz/Vert Lines "));
Serial.println(testFastLines(ILI9341_RED, ILI9341_BLUE));
Serial.print(F("Rectangles (outline) "));
Serial.println(testRects(ILI9341_GREEN));
Serial.print(F("Rectangles (filled) "));
Serial.println(testFilledRects(ILI9341_YELLOW, ILI9341_MAGENTA));
Serial.print(F("Circles (filled) "));
Serial.println(testFilledCircles(10, ILI9341_MAGENTA));
Serial.print(F("Circles (outline) "));
Serial.println(testCircles(10, ILI9341_WHITE));
Serial.print(F("Triangles (outline) "));
Serial.println(testTriangles());
Serial.print(F("Triangles (filled) "));
Serial.println(testFilledTriangles());
Serial.print(F("Rounded rects (outline) "));
Serial.println(testRoundRects());
Serial.print(F("Rounded rects (filled) "));
Serial.println(testFilledRoundRects());
Serial.println(F("Done!"));
void loop(void) {
for(uint8_t rotation=0; rotation<4; rotation++) {
tft.setRotation(rotation);
testText();
unsigned long testFillScreen() {
unsigned long start = micros();
tft.fillScreen(ILI9341_BLACK);
yield();
tft.fillScreen(ILI9341_RED);
yield();
tft.fillScreen(ILI9341_GREEN);
yield();
tft.fillScreen(ILI9341_BLUE);
yield();
yield();
return micros() - start;
unsigned long testText() {
tft.setCursor(0, 0);
tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2);
tft.println(1234.56);
tft.setTextColor(ILI9341_RED); tft.setTextSize(3);
tft.println(0xDEADBEEF, HEX);
tft.println();
tft.setTextColor(ILI9341_GREEN);
tft.setTextSize(5);
tft.println("Groop");
tft.setTextSize(2);
tft.println("I implore thee,");
tft.setTextSize(1);
tft.println("my foonting turlingdromes.");
tft.println("And hooptiously drangle me");
tft.println("with crinkly bindlewurdles,");
tft.println("Or I will rend thee");
tft.println("in the gobberwarts");
tft.println("with my blurglecruncheon,");
tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
unsigned long start, t;
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
yield();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
x2 = w - 1;
for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
t = micros() - start; // fillScreen doesn't count against timing
yield();
yield();
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
t += micros() - start;
yield();
yield();
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
yield();
yield();
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
yield();
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
unsigned long start;
int x, y, w = tft.width(), h = tft.height();
start = micros();
for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
int n, i, i2,
cx = tft.width() / 2,
cy = tft.height() / 2;
n = min(tft.width(), tft.height());
start = micros();
for(i=2; i<n; i+=6) {
i2 = i / 2;
tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
unsigned long start, t = 0;
int n, i, i2,
cx = tft.width() / 2 - 1,
cy = tft.height() / 2 - 1;
for(i=n; i>0; i-=6) {
i2 = i / 2;
start = micros();
tft.fillRect(cx-i2, cy-i2, i, i, color1);
// Outlines are not included in timing results
tft.drawRect(cx-i2, cy-i2, i, i, color2);
yield();
return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
start = micros();
for(x=radius; x<w; x+=r2) {
for(y=radius; y<h; y+=r2) {
tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
int x, y, r2 = radius * 2,
w = tft.width() + radius,
h = tft.height() + radius;
// Screen is not cleared for this one -- this is
// intentional and does not affect the reported time.
start = micros();
for(x=0; x<w; x+=r2) {
for(y=0; y<h; y+=r2) {
tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
int n, i, cx = tft.width() / 2 - 1,
n = min(cx, cy);
start = micros();
for(i=0; i<n; i+=5) {
tft.drawTriangle(
cx , cy - i, // peak
cx - i, cy + i, // bottom left
cx + i, cy + i, // bottom right
tft.color565(i, i, i));
unsigned long testFilledTriangles() {
int i, cx = tft.width() / 2 - 1,
start = micros();
for(i=min(cx,cy); i>10; i-=5) {
start = micros();
tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(0, i*10, i*10));
tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(i*10, i*10, 0));
yield();
return t;
unsigned long testRoundRects() {
int w, i, i2,
w = min(tft.width(), tft.height());
start = micros();
for(i=0; i<w; i+=6) {
i2 = i / 2;
tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
int i, i2,
start = micros();
for(i=min(tft.width(), tft.height()); i>20; i-=6) {
i2 = i / 2;
tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
yield();
Hatte das ja alles schon runtergeladen, wie Du auch richtig annimmst.
Auch die User_Setup.h hatte ich schon nach libraries/TFT_eSPI kopiert.
Habe auch die Adafruit_ILI9341 in libraries installiert, also ganz normal im IDE installiert und das Projekt 1-Adafruit_ILI9341_Test geöffnet.
Kompilert auch und wenn ich es ausführe, sieht man, daß die Demo nur in einem quadratischen Teil des Screens läuft oder der Screen ist um 90° gedreht, was eher danach aussieht. Irgendwie kriegt er die Screenabmessungen nicht mit.
Und die Demo ist relativ langsam. Aber das liegt wohl am SPI. Das muß ich bei der Boardarchitektur halt hinnehmen, denn auf parallel-Ansteuerung werde ich das wohl nicht umbauen können.
Kompilert auch und wenn ich es ausführe, sieht man, daß die Demo nur in einem quadratischen Teil des Screens läuft oder der Screen ist um 90° gedreht, was eher danach aussieht. Irgendwie kriegt er die Screenabmessungen nicht mit.(x/y vertauscht?)
Was zeigt an bei TFT_eSPI?
Muss mir mal anschauen was die bei UserSetup produziert haben,
Was meinst Du genau? Ich habe die User_Setup.h in das TFT_eSPI Verzeichnis kopiert.
Dan nimm erstes bestes Beispiel aus der Lib.
zb: TFT_Clock
Schön, jetzt kannst rumspielen, wen Fragen wegen der Lib fragen, habe mich ziemlich gut eingearbeitet.
Mache 90% mittlerweile nur mit der Lib.
Noch was, habe mir bestellt die Stecker für das Display, wenn die ankommen und passen, kann den Link geben, bei meinem war nur einer dabei.
Du hast ja Resistiven Touchscreen, die TFT_eSPI kann den auch auslesen.
Das Display ist 2,8" und hat m.W. kapazitiven Touch, meine ich gelesen zu haben.
OK, das kann die TFT Lib nicht, meine hat auch kapazitiven Touch.
Erst mall muss ich alte Sachen abarbeiten, danach kommt das Ding dran ![]()
In der Doku der TFT_eSPI steht:
"Support for the XPT2046 touch screen controller is built into the library and can be used with SPI interface displays. "
und:
The XPT2046 touch screen controller is supported for SPI based displays only. The SPI bus for the touch controller is shared with the TFT and only an additional chip select line is needed. This support will eventually be deprecated when a suitable touch screen library is available.
The Button class from Adafruit_GFX is incorporated, with the enhancement that the button labels can be in any font."
Was ich aber nirgends finde, ist ein Programming Manual, wo die Funktionen dokumentiert sind.
Ich brauche dotted oder patterned lines. Setzen von RGB-Farben.
Das wird Schwierig so ich weis unterstützt die nur
fillRectVGradient und fillRectHGradient also 2Punkt Rechtecke bauen.
Beschreibung gibt's nicht nur das was in der TFT_eSPI.h steht.
Gestrichelte, gepunktete Linien musst schon selber Bauen, habe noch bei keiner Lib gesehen
Ist doch Decoder-IC für Widerstands-Touchscreens, Muss mal schauen ob der auch Kapazitive kann. aber nicht mehr Heut ![]()
Hier mal eine ganz andere Frage: das ist hier zwar ein Arduino Forum, aber man kann ja auch unter VScode und dem ESP-IDF plugin (oder dem PlatformIO plugin, mich interessiert allerdings das erstere) die Arduino Beispiele, z.B. die obige TFT_Clock kompilieren und flashen, oder?
Dann müßten die Arduino libraries und Includes ja umkonfiguriert werden für das ESP-IDF Environment. Weiß jemand, wo man da am besten einsteigt? Tutorial, Wiki, HowTo?
