won"t compile
:frowning: ok: using the "starter kit" by DFRobot. Using their code (project 13). I copy line by line into my sketch. I compile after each line I write. When I get to a specific line, the code won"t compile. I cannot find //motor with button control
int buttonPin = 2;
int relayPin = 3;
int relayState = HIGH;
int buttonState;
int lastButtonState;
long lastDebounceTime = 0;
long debounceDelay = 50;
pinMode(buttonPin, INPUT);
pinMode(relayPin,OUTPUT);
digitalWrite(relayPin, relayState);
int reading = digitalRead(buttonPin);
if (reading != lastButtonState){
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay){
if (reading != buttonState){
buttonState = reading;
} wrong. Can someone please help me so I can sleep at night. Thanks
the problem line is: if ((millis() - lastDebounceTime) > debounceDelay){
It’s not going to compile without a loop(). But there are no compilation errors with that if statement.
Try posting the code properly in </> code tags and if you’re getting an error please also post the COMPLETE error message.
Steve
Thanks for the reply. I normally use comments when I code but I have been re-entering this sketch too many times , trying to figure out what is happening. This was my first attempt to cut and paste. It will get better.
The error code is "error 1" I have no idea what that means. Is there a listing of error codes?
Hopefully, there's more than just "error 1".
Try scrolling back
Why ? Your program will not compile until there is at least a setup() and loop() function.
int buttonPin = 2;
int relayPin = 3;
int buttonState;
the DFRobot project is #13: Motor Fan
I made a mistake (again) my code will not "verify" past : if((millis() - lastDebounceTime) > deBounceDelay){
Post the actual complete error message. I'm guessing it says something about main() and an undefined reference to loop().
Which is because you insist on ignoring us when we tell you that you NEED a loop() if you want it to compile.
Steve
and you also need the setup() function to end with a }
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
When you open a NEW code page in the IDE, you will see the minimum requirements to make your code.
please compare it with your code.
As has been repeated many time you are missing
at the end of your code.
Tom... :slight_smile:
You're right, he's missed that out again. Trying to compile incomplete code a line at a time really is the most pointless waste of time.
Well it's not going to waste any more of my time.
Steve
If "the DFRobot project is #13: Motor Fan" has code to go with it, compare it to yours.
You cannot write a line of code and compile after each line is added.
The compiler does not just check your lines of code but the overall STRUCTURE of your code, so you have to also include the bare necessities of the program structure.
Is one of them.
Do not get fixated on the millis() statement error.
Tom.... :slight_smile:
//Project thirteen - the Arduino to control fan operation
int buttonPin = 2;                  // int buttonPin = 2;
int relayPin = 3;                   // int relayPin = 3;
int relayState = HIGH;              // int relayState = HIGH;
int buttonState;                    // record the current button state
int lastButtonState = LOW;          // record the last button state
long debounceDelay = 50;            // eliminate debounce time
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, relayState);  // configure the initial state of relay
int reading = digitalRead(buttonPin);             //read the value of button
// once detects change of state, record time
if (reading != lastButtonState) {
// wait for 50ms to evaluate if it is the same state as last state
// if different, change the button state
// if the state of button is high(pressed), change the state of relay
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
if (buttonState == HIGH) {
relayState = !relayState;
//change the last state of button
lastButtonState = reading;
Entering all of the code first might solve your problems.
G
I want to thank you all for the help. Sorry for my lack of experience.. YES.. my sketch needed a "void loop()" . My way of thinking was that it was not needed to "verify " lines of code. I am learning, thanks.
