Won't start logging gps data unless I open serial monitor... agh!
So I am working on a cheap lidar system that I can mount on my phantom and fly it around and hopefully get some data back. Its for a school project and I have managed to get the code to give me text file with lat, lon, altitude, and distance. great I thought, except once I have it operating on its own nothing happens, only when I start the serial monitor does it create a log. I have just about given up and decided to see if anyone can help... help.
Here is the code...
#include <SD.h>
#include <SPI.h>
#include <SoftwareSerial.h>
#include "TinyGPS++.h"
#include <I2C.h>
#define LIDARLite_ADDRESS 0x62 // Default I2C Address of LIDAR-Lite.
#define RegisterMeasure 0x00 // Register to write to initiate ranging.
#define MeasureValue 0x04 // Value to initiate ranging.
#define RegisterHighLowB 0x8f // Register to get both High and Low bytes in 1 call.
int ledPin = 9;
int programStatus = 0;
File file;
String longtitude;
String latitude;
String dayString;
String monthString;
String altString;
int id = 0;
TinyGPSPlus gps;
SoftwareSerial ss(8, 7);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
ss.begin(9600);
programStatus = initializeSD();
delay(3000);
openFileToWrite("log.csv");
writeHeaderToFile();
I2c.begin(); // Opens & joins the irc bus as master
delay(100); // Waits to make sure everything is powered up before sending or receiving data
I2c.timeOut(50); // Sets a timeout to ensure no locking up of sketch if I2C communication fails
int lidargetDistance(){
// Write 0x04 to register 0x00
uint8_t nackack = 100; // Setup variable to hold ACK/NACK resopnses
while (nackack != 0){ // While NACK keep going (i.e. continue polling until sucess message (ACK) is received )
nackack = I2c.write(LIDARLite_ADDRESS,RegisterMeasure, MeasureValue); // Write 0x04 to 0x00
delay(1); // Wait 1 ms to prevent overpolling
byte distanceArray[2]; // array to store distance bytes from read function
// Read 2byte distance from register 0x8f
nackack = I2c.read(LIDARLite_ADDRESS,RegisterHighLowB, 2, distanceArray); // Read 2 Bytes from LIDAR-Lite Address and store in array
return (distanceArray[0] << 8) + distanceArray[1]; // Shift high byte [0] 8 to the left and add l
String entry;
String hourString;
String minuteString;
String secondsString;
while (ss.available() > 0)
gps.encode(ss.read());
if (gps.location.isUpdated())
programStatus = 2;
blinkQuickly();
latitude = String(gps.location.lat(),5);
longtitude = String(gps.location.lng(),5);
dayString = String(gps.date.day());
monthString = String(gps.date.month());
hourString = String(gps.time.hour());
minuteString = String(gps.time.minute());
altString = String(gps.altitude.meters());
if(gps.time.hour()<10)
hourString = "0"+String(gps.time.hour());
if(gps.time.second()<10)
secondsString = "0"+String(gps.time.second());
secondsString = String(gps.time.second());
id++;
int distance = lidargetDistance();
entry = String(id)+","+dayString+"/"+monthString+","+hourString+":"+minuteString+":"+secondsString+","+latitude+","+longtitude+","+altString+","+distance;
writeEntryToFile(entry);
else if(programStatus == 1)
delay(300);
digitalWrite(ledPin,LOW);
delay(300);
int initializeSD()
Serial.println("Initializing SD card...");
pinMode(10, OUTPUT);
if (SD.begin(4))
Serial.println("SD card is ready to use.");
return 1;
} else
Serial.println("SD card initialization failed");
return 0;
int openFileToWrite(char filename[])
file = SD.open(filename, FILE_WRITE);
if (file)
return 1;
} else
return 0;
int writeToFile(String text)
if (file)
file.println(text);
return 1;
} else
return 0;
void closeFile()
if (file)
file.close();
void writeEntryToFile(String entry)
openFileToWrite("log.txt");
Serial.println(entry);
writeToFile(entry);
closeFile();
void blinkQuickly()
delay(100);
delay(100);
void writeHeaderToFile()
writeToFile("Id,Date,Time,Latitude,Longitude,Altitude,Distance");
closeFile();
Read How to post code properly and then fix up your message with [code]// your code here[/code] tags.
Pete
wolf4202:
Here is the code...
[snark on]
I assume you are using a AtTiny85 right? and you are questioning why nothing appears on your computer screen when it is not plugged into your computer?
[/snark off]
What Arduino are you using?
Why are you writing to Serial if you are not going to connect the Serial to a display?
If this is designed to function without a USB connection do you have something else connected to pins 0,1?
from your code:
 closeFile();
 writeToFile(entry);
 closeFile();
If i am reading your program correctly, you open the file, write this header to the file, close the file and reopen the file OVERWRITE ANYTHING in the FILE, write more data? rinse and repeat?
use one of the Arduino pins for a 'Mode' control,
Ground(LOW) = 'capture Data',
open(HIGH) = stop capture, close file
use one of the Arduino pins as a switch, around all Serial() calls put
#define debugPin someUnusedPinOnTheArduino
#define modePin anotherUnusedPinOnTheArduino
void blink(uint16_t offTime, uint16_t onTime){
digitalWrite(LED_BUILTIN,LOW);
delay(offTime);
digitalWrite(LED_BUILTIN,HIGH);
delay(onTime);
static bool flightMode=false;
void setup(){
pinMode(modePin,INPUT_PULLUP); // ground this pin for 'flight mode', no Serial output
 // remove the jumper to stop logging, close file
pinMode(debugPin,INPUT_PULLUP); // ground this pin for inHibit debug Serial Output
pinMode(LED_BUILTIN,OUTPUT); // Status message LED on Pin13 of Arduino Uno
// other setup stuff hardware, software, devices
If(!digitalRead(modePin)){ // mode is LOW therefore flight mode
  If(digitalRead(debugPin)) Serial.println(F("Entering Flight Mode"));
  char ch[50];  //filename buffer
  uint16_t fnum=0;
  do{  //find new unused file, don't overwrite existing data files
    fnum++;
    sprintf(ch,"log%05u.txt",fnum); // create text string "log00001.txt", the file name
    }while(SD.exists(ch));
  If(digitalRead(debugPin)){
     Serial.print(F("Using File:"));
     Serial.println(ch);
  if(openDatafile(ch)){
    flightMode=true;
    writeFileHeader();
    digitalWrite(LED_BUILTIN,HIGH); // turn on Led to indicate logging!
  else {
     // bad stuff happend! could not open file :(
    Serial.println(F(" file open Failed!! going TA!"));
    while(true) blink(50,150);
    } // end openfileFail!
  }// end if(flight)
}// end setup
if(digitalRead(modePin)&&flightMode) { // well it looks like the flight is over and the mode jumper is removed
  // close the file
  if(digitalRead(debugPin)) Serial.println(F(" Closing Datafile, Flight is over!"));
  closefile();
  if(digitalRead(debugPin)) Serial.println(F(" File Closed\nJumper Flight Pin\n"
      "Reboot for Next Flight"));
  flightMode = false;
  while(true) blink(100,300); // lockup, waiting for power off,
else { // flight mode, read sensors, store results in SD card file.
/* put this if statement around all your 'Debug' serial messages */
if(digitalRead(debugPin)) Serial.print(F("bla bla bla bla bla debug stuff"));
/* use the F("message") construct to save Ram.
 * every constant message in you program uses one byte of RAM for each Byte of message.
 * the F("message") does not reserve RAM to hold a copy of the message, it just accesses it directly
 * from the Program Memory (FLASH)
Chuck.
