I'd sure appreciate some initial guidance on creating an Arduino based unit to monitor 4 different temperatures of a wood fired pizza oven As well I'd like to be able to monitor the temperatures in real time on an LCD screen. I've been able to connect 4 thermocouples to my Uno R3 and read the temps on my PC, but when I try to connect an LCD I run out of digital pins. HMMM! Where would be a good starting point in sorting this out?
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Can you please post a copy of your sketch, using code tags?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
We can then offer some advice.
Thanks....Tom... ![]()
Remember analog pins can also be used as digital pins. Although they have digital numbers, it is best to use the "A" names for them:
const int LCDEnablePin = A0;
digitalWrite(LCDEnablePin, HIGH);
4 analog inputs
usb serial?
leaves a lot of free pins !
Serial connection uses fewer pins.
need more data about how you are using pins
You could also use a I2C interface for the LCD.
Weedpharma
I'm using the wiring configuration that is suggested at the Adafruit TC Tutorial (Arduino Code | MAX31855 Thermocouple | Adafruit Learning System). I'm using a Max31855 Braekout Board and the DO is connected to DO3, CS to DO4 and CLK to DO5. To connect two TC's (Breakout boards) I've edited the sketch to accommodate a second TC.
#include <SPI.h>
#include "Adafruit_MAX31855.h"
#define DO 3
#define CS1 4
#define CS2 6
#define CLK 5
Adafruit_MAX31855 thermocouple1(CLK, CS1, DO);
Adafruit_MAX31855 thermocouple2(CLK, CS2, DO);
I did not realize the Analog pins could be used as digital pins. That alone may sole my dilemna.
Thanks for suggestions. It's reassuring to know that this at least possible.
Hi
Can you please post a complete copy of your sketch, using code tags?
Tom... ![]()
If you are searching for a Wood Fired Pizza Ovens, you should check "ilFornino" Pizza Ovens.
